Bryant Inducer Board Testing? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-06-2008, 08:27 PM   #1
bryant inducer board testing?
hey guys, I was told by the heater guy the inducer board was bad in my bryant furnace, before I buy another one to install can I test the board out of the furnace? It is not putting voltage through to the inducer motor although it has voltage coming in. Is there a bench test for it? thanks in advance, boomer
boomerbaird is offline   Reply With Quote
Old 01-06-2008, 09:17 PM   #2
Union HVAC Tech.
It would be complicated to do out of the furnace but easy in the furnace. Leave all the wiring hooked up as normal, just remove the leads to the inducer and hook up a volt meter, either it will give out 120volts or it won't. To check the inducer, just power it up with a adapter cord and check the running amps with an amprobe. It's that simple.
bigMikeB is offline   Reply With Quote
Inducer installation / modification ... caseywa HVAC 26 12-06-2010 01:50 PM
bryant inducer board part number? boomerbaird HVAC 3 01-03-2008 05:54 PM
Inducer motors on Bryant 350AAV Rookietinner HVAC 1 02-18-2007 03:38 PM
bryant furnace will not light somany?'s HVAC 16 11-29-2006 08:28 PM
Bryant Inducer Fan Runs Constantly biglittledan HVAC 4 11-24-2006 11:23 AM
