Bryant Gas Pack Blower Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 10-27-2012, 04:22 PM   #1
Bryant gas pack blower fan
Just got a old fixer upper house for my mother to move into.
The indoor blower motor run all the time no matter what setting thermostat is on
even in off, it keeps going, is this a bad thermostat.
thanks for any help
dalem is offline   Reply With Quote
Old 10-27-2012, 04:51 PM   #2
The previous owners could have set it up that way. Check the control board for a jumper from R to G.
hvac benny is offline   Reply With Quote
Old 10-28-2012, 02:18 PM   #3
Thanks HVAC Benny
I found no jumper, but the wires are in a mess, a lot of cuts & splices.
Thanks for the tip.
Old 10-28-2012, 03:25 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
it could be a blown low voltage fuse or an open limit that is causing the fan to run all the time. Does the heat or a/c work?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 11-12-2012, 02:43 PM   #5
bad wiring
When I had time to trace the wiring, it was wired hot full time, just to simple to look for at first. Thanks
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
blower problems with bryant furnace. blowerissue HVAC 4 03-13-2012 11:34 PM
Blower NOT continuously ON on Bryant 310AAV rational HVAC 5 08-15-2011 08:44 PM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 09:08 PM
