-   -   Bryant gas furnace internal water leak.... (http://www.diychatroom.com/f17/bryant-gas-furnace-internal-water-leak-26681/)
naexec 09-11-2008 07:38 PM
I have a Bryant energy efficient gas furnace that was installed when the house was built in1994. The vent and air intake are through the side with PVC piping to the outside wall of the house.
About 3 years ago, I replaced the rubber drain tube inside which had rotted out and leaked.
Last winter, when it got cold, the furnace began leaking water/condensation again, but this time from the internal case/unit where the tube attaches to the nipple inside the furnace. It appears to seep water from the backside of this unit (toward the burners), onto the metal pan inside and then onto the basement floor though seams, etc. in the furnace jacket. The tube drain still works but appears a lot of water is leaking out from the unit before it gets to that normal outlet.
My question is, the case where the leak is coming from servicable/repairable? If so, is there a replacement that is available/gasket/seals inside? possible cracked housing/case? Or, does the furnace need to be replaced re cost effective, etc...
Thx,
naexec
sgthvac 09-11-2008 11:22 PM
naexec,
Sounds like the secondary heat exchanger is leaking at a seam. You would have to check about the warranty, but Bryant normally has at least a 20 yr wnty on the heat exchanger. You really should contact your local contractor to be better way your options. With a 14 yr old furnace you might be better off upgrading your system depending on what your local contractor charges to replace the heat exchanger if that is indeed the problem. When your system is 14 yrs old, the decision is how much money do I drop into it? It's like a car with a 100,000 miles do you repair or trade it in? Just so you know ave. life of furnaces is 15-20yrs, ac is 10-15.
JackA 10-04-2008 07:26 PM
Bryant leaks water
This is condensation in the furnace heat exchanger that is collected in that cover the hose connects to. The problem is the factory original is pot metal that has corroded and is leaking. Get it replaced immediately before that water gets to the electrical and electronics. I did it myself, takes a little effort, but if handy at all, can be done. The new one is a composite, so should last forever. For reference, this is mounted to the back wall in the gas valve area, about 8 or so inches high, about 12 inches wide, maybe 1 1/2 inches deep.
hvaclover 10-04-2008 09:56 PM
Bryants of that vintage are now subject to a class action law suit.
Bryant is giving special court ordered discounts. Call a Bryant dealer to see if you qualify for a new unit.
JackA 10-05-2008 11:21 AM
Class-action
Quite a gig these class-action lawyers got - they get BIG bucks, the consumer rarely gets anything of real value......
hvaclover 10-05-2008 11:32 AM
Regardless of what lawyers get it's probably covered Just check it out.
The failure could be life threatening.
notarascal 11-25-2008 01:40 AM
Bryant leaker
I noticed water leaking from the base of my eight year old Bryant 90+ furnace about a week ago. I called the tech who installed it and he found that the secondary heat exchanger was leaking due to corrosion. He installed the replacement provided by Bryant under warranty. By the end of the day the replacement unit was leaking. The tech came back today and found the cheapo schmutz used to glue the tubes in place was bad (one tube had no sealant at all). He called Bryant and they sent a replacement out to the house via courrier. The tech installed the replacement. It's been running for 6 hours and guess what... the replacement for the replacement is leaking. I'll be calling the tech tomorrow. I think it's time to have this unit pulled out and a new furnace installed. We'll see how "Hospitable" Bryant is with their warranty. I sure don't trust their products. The G.E. that this thing replaced was 20 years old and never gave us a problem. The only reason I replaced the G.E. was so I could eliminate the chimney flue to accomodate some remodeling. What a pain in the behind.
:wallbash:
