Old 11-06-2009, 11:11 PM   #16
heres-two
pipebender is offline   Reply With Quote
Old 11-06-2009, 11:19 PM   #17
and-heres-3
bryant-gas-furnace-burner-wont-stay-dscf1675.jpg   bryant-gas-furnace-burner-wont-stay-dscf1677.jpg   bryant-gas-furnace-burner-wont-stay-dscf1681.jpg
Old 11-06-2009, 11:23 PM   #18
electric company put this in so they can control stuff.
bryant-gas-furnace-burner-wont-stay-dscf1674.jpg   bryant-gas-furnace-burner-wont-stay-dscf1678.jpg   bryant-gas-furnace-burner-wont-stay-dscf1679.jpg
Old 11-06-2009, 11:28 PM   #19
Houston204's Avatar
Can you see the inlet side (bottom) of your vertical coil?
Houston204 is offline   Reply With Quote
Old 11-06-2009, 11:37 PM   #20
how can i see? from downby the blower? i tOOK off the panel on top for ac coil and its clean.
Old 11-06-2009, 11:52 PM   #21
Houston204's Avatar
The triangular panel in the center of your A coil will allow viewing of your inlet side.
Removing the blower and snapping some pictures through the heat exchanger would be less likely to cause a refrigerant leak if the A coil center panel is blocked by too many feeder tubes.
Old 11-07-2009, 10:25 AM   #22
old pro
Check the rating sticker in the furnace. Should tell you a recommended temp rise thru the unit. Ie 40-80 degF. Do a temp rise test. Check the supply temp a foot downstream from the plenum and subtract it from the return temp. That black box is a combo fan/limit control made by camstat and fail a lot when old. I would not swap the other one from your other furnace as it is so old and brittle it will probably fail and then you will need to buy 2 of them. Should still be available (Johnstones/Grainger)?. Check the coil for blockage if you can. SERIOUSLY, you need 2 NEW CO detectors for your house as the heat exchanger is NOT in good shape and may be cracked. One for your bedroom, the other in a stairwell going upstairs from the basement.
Old 11-07-2009, 10:49 AM   #23
i would recommend you call somebody that knows what they are doing to check that furnace ,i have found many of them with the heat exchanger rusted out. also do you have to add freon to that system as it looks like oil on the bottom of the a coil . the part of the coil you are seeing is not the side that gets dirty it is the side you dont see try lifting up on the coil and look at the heat exchanger look for holes also look inside the coil with a mirror see if it is clogged
mrairflow is offline   Reply With Quote
Old 11-07-2009, 10:58 AM   #24
Easiest DIY heat exchanger check on that furnace is
1) turn off the power
2]remove the blower,camstat and burners
3) look inside the heat exchanger with a bright flashlight for cracks or excessive rust
4) wet down the outside of the heat exchanger from the blower compartment on up with water.
5) look inside the heat exchanger again with the light
Any cracks or rust holes will show up as damp spot that was not there on the first visual inspection. Cracks usually happen along the back of the heat exchanger and near bends. There's no middle ground here, it leaks or it doesn't.
Old 11-07-2009, 11:48 AM   #25
ok im going to try the temp rise test. i got a infrared thermo to use. i looked on grainger and i see one similiar. does this problem sound like a fan/limit switch? should i just order one? i got 3 co detectors in the house one is the basment one at the top of the steps and on by my kitchen cause i got a gas stove. if the heat exchanger is cracked would i still be getting a real nice blue burner flame? so my problem sounds like it had nothing to do with my fancy thermostat controller?
Old 11-07-2009, 11:54 AM   #26
i have not put freon on that side of the units in 16 years. im going to take the blower out and the a/c coil access cover to get a better look again.
Old 11-07-2009, 11:58 AM   #27
im going to give that a try.
THANKS AGAIN EVERYONE FOR ALL YOUR HELP!
Old 11-07-2009, 12:28 PM   #28
old pro
The color of the flame won`t tell you if it is cracked. I would CAREFULLY inspect the heat exchanger B4 spending any $$ on repairs. The fancy controller looks like a load shedder to allow them to shutoff your AC in peak times and give you a lower $rate. Those camstats, fan controls fail a lot in old age. You need a cooking or stick type thermometer to insert into the airstream of the duct.
Good Luck
Old 11-08-2009, 08:58 PM   #29
Smile
welly welly well!!!!! i changed out the fan limt switch from my other unit and it fired right up!!! so far so good. sucks for my tenants but im a slumlord...... lol i already told them the deal. thanks for everyone trying to help me. after looking at the wiring schematic i found on the net. i started measuring out points with my multimeter and comparing them to my other unit both calling for heat. i found the power stoped at the fan switch. this sucker lasted for a long time good lord. date stamp on it was 12/73 camstat 01-0584a stamped on the side. it dont even look up on there cross reference at camstats website i gotta call. looks like they aint based in cali anymore either cause stamped in mine says los angeles ca now they in chatem il. is there any way i can rebuild this switch or jus buy a new one? CHEERS!!!!
Old 11-08-2009, 09:41 PM   #30
old pro
Buy a new one, not rebuildable or SAFE to do so.
Tags
bryant gas furance
More On This Topic
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to check your furnace filter. The first thing you need to do is locate your furnace. Now in many houses, the furnace is located in the laundry room which is in the... Read More »
There are many types of furnaces and they all need their filters replaced periodically. Changing your furnace filter can be easy if you know where it is located or it can be downright frustrating if you can't find the thing. Read More »
Hi! This is Jon for Expert Village. In this video clip I will be showing you step 1 for installing a smoke detector. Now there should be a smoke detector installed in every room of your house including every hallway. This room does not have a smoke... Read More »
A few things to have in the house for fire safety would be a smoke detector for at least each room. You need a fire extinguisher in the kitchen and the garage. A carbon monoxide detector where you might have any gas appliances, whether it be by the... Read More »
Hi! My name is Jeff Thompson for Thompson Air hot air balloon rides and I am here with Expert Village and today we are going to talk about the bottom end. The bottom end is what pilots refer to as their basket of a hot air balloon. Anything that goes... Read More »
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 10:56 AM
Lennox Furnace burner won't stay on stevea7777 HVAC 6 01-25-2009 10:06 PM
Bryant +80 Gas Furnace won't light tr0910 HVAC 4 01-14-2009 09:11 AM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 4 01-26-2008 10:20 PM
Burner on Bryant furnace won't come on Flylowflyslow HVAC 1 09-19-2007 02:57 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
