Bryant Furnace Won't Run - HVAC - DIY Chatroom Home Improvement Forum
Old 10-21-2012, 01:02 PM   #1
Bryant furnace won't run
I have a Bryant 383 KAV furnace. It is not running in the heat mode. I followed the trouble tree in the manual; there were no codes flashing, the component test ran and everything worked. I cleaned off the flame sensor and, as the book recommended, replaced the control panel. The furnace still doesn't run it doesn't do anything. There is 24v at the W Y and G terminals. Any thoughts?
mswarms is offline   Reply With Quote
Old 10-21-2012, 02:03 PM   #2
JJboy's Avatar
Check the voltage at Induce Draft Motor.
Check the voltage at Pressure switch.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-21-2012, 06:34 PM   #3
how
Rewards Points: 1,070
Turn off furnace power and remove thermostat lines from furnace connections R & W.
Jumper R & W and turn power back on.
What happens?
how is online now   Reply With Quote
16-year old Bryant Plus-90 furnace phillip9 HVAC 5 03-05-2013 02:11 PM
Bryant Furnace Blower Won't Shut Off aorozco HVAC 3 12-02-2010 02:20 AM
air cycler install for bryant 90 gas furnace bill c Electrical 1 10-29-2010 10:53 AM
Bryant Furnace pilot not lighting DGB HVAC 2 05-31-2009 12:47 PM
Bryant gas furnace internal water leak.... naexec HVAC 6 11-25-2008 01:40 AM
