Bryant Furnace Won't Light, Not HSI - HVAC - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 09:19 AM   #1
Bryant furnace won't light, not HSI
My furnace won't light. The HSI glows red and I've cleaned out the burners. The safety switch has been reset but the furnace still won't light. Any ideas?
amylynn6 is offline   Reply With Quote
Old 10-30-2010, 10:33 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 382
Gas turned on outside and at the gas valve? Post the model and serial # and pics of it with front door off. Is it Propane or nat. gas?
Old 10-30-2010, 11:13 AM   #3
It's a 395CAV024055 nat. gas.
I've checked the safety switch, scrubbed the flame sensor bar with steel wool, cleaned the burners to get rid of any dust and still nothing. Yes, my gas line is open.
Still no heat. Open to ideas!
Old 10-30-2010, 11:29 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 382
As soon as the HSI starts to glow check for 24 volts AC on the 2 wires at the gas valve. If none then the circuit board may be bad.
Old 10-30-2010, 11:56 AM   #5
I'm not getting any gas through the pipe into the burners. I can't get the picture to upload and I don't have any testers to check for volts. How could I tell if the box that the gas flows through is bad?
Old 10-30-2010, 12:23 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 382
You need a voltage meter to do that. Buy a reasonably good $30 and up one from Sears. The cheaper ones are not reliable, you get what you pay for.
http://www.sears.com/shc/s/p_10153_12605_03482139000P
Old 10-30-2010, 06:06 PM   #7
Still no volt meter but one other tidbit of information. A few weeks ago I started my furnace and it fired and heated fine. Then I turned off the furnace. Yesterday when I started the furnace, there was no ignition. Any other ideas? Thank you for your help!
Old 10-30-2010, 06:18 PM   #8
HVAC / Plumbing
Like Yuri said, You have to have a vm to check these furnaces so, you'll know where problems are
kenmac is offline   Reply With Quote
Old 11-01-2010, 10:07 AM   #9
Does the furnace shut off at some point for good and have a blink code? If so, what is the blink code and what does it reference to?
I had the same issue with an ignition blink code on my bryant, first think I scrubbed the sensor, listened for the gas valve to open and of course the smell test, and then seen my HSI was cracked.
If you have a blink code, it usually tells you what to look for.
DAdams982 is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Bryant 355MAV furnace Beaumont General DIY Discussions 8 10-22-2010 07:27 AM
bryant gas furnace burner wont stay on. pipebender HVAC 29 11-08-2009 07:41 PM
Pilot Light works once, then have to re-light after furnace goes off aransas42 HVAC 8 09-30-2009 07:49 AM
Furnace won't light Babybird HVAC 2 03-30-2007 09:48 AM
