-   -   Bryant furnace won't light, not HSI (http://www.diychatroom.com/f17/bryant-furnace-wont-light-not-hsi-85282/)
amylynn6 10-30-2010 10:19 AM
My furnace won't light. The HSI glows red and I've cleaned out the burners. The safety switch has been reset but the furnace still won't light. Any ideas?
yuri 10-30-2010 11:33 AM
Gas turned on outside and at the gas valve? Post the model and serial # and pics of it with front door off. Is it Propane or nat. gas?
amylynn6 10-30-2010 12:13 PM
It's a 395CAV024055 nat. gas.
I've checked the safety switch, scrubbed the flame sensor bar with steel wool, cleaned the burners to get rid of any dust and still nothing. Yes, my gas line is open.
Still no heat. Open to ideas!
yuri 10-30-2010 12:29 PM
As soon as the HSI starts to glow check for 24 volts AC on the 2 wires at the gas valve. If none then the circuit board may be bad.
amylynn6 10-30-2010 12:56 PM
I'm not getting any gas through the pipe into the burners. I can't get the picture to upload and I don't have any testers to check for volts. How could I tell if the box that the gas flows through is bad?
yuri 10-30-2010 01:23 PM
You need a voltage meter to do that. Buy a reasonably good $30 and up one from Sears. The cheaper ones are not reliable, you get what you pay for.
http://www.sears.com/shc/s/p_10153_12605_03482139000P
amylynn6 10-30-2010 07:06 PM
Still no volt meter but one other tidbit of information. A few weeks ago I started my furnace and it fired and heated fine. Then I turned off the furnace. Yesterday when I started the furnace, there was no ignition. Any other ideas? Thank you for your help!
kenmac 10-30-2010 07:18 PM
Like Yuri said, You have to have a vm to check these furnaces so, you'll know where problems are
DAdams982 11-01-2010 11:07 AM
Does the furnace shut off at some point for good and have a blink code? If so, what is the blink code and what does it reference to?
I had the same issue with an ignition blink code on my bryant, first think I scrubbed the sensor, listened for the gas valve to open and of course the smell test, and then seen my HSI was cracked.
If you have a blink code, it usually tells you what to look for.
