Old 11-29-2006, 09:18 PM   #16
bryant furnace will not light
Rusty,
I'm not sure if it has the valve your speaking of, i know it is original to the unit. The numbers on the valve are 8342-3
model# 646ax
p/n 301273-703
I hope this what you asked for(they are kinda smudged and hard to read), if not I will try again. Is installing a gas valve complicated ?
Thank you for all of your help, I really do appreciate it.
somany?'s is offline   Reply With Quote
Old 11-29-2006, 09:28 PM   #17
Thoroughbred Mopar Man
Hi somany?'s
Installing the gas valve is slightly labor intensive. You will need a 7/16" open end wrench, two descent pipe wrenches, nothing less than a twelve inch pipe wrench. Some teflon pipe dope and possibly a 5/16" nut driver. Shut the power and the gas off to the furnace. Be extremly careful not to break anything, outside of what I have listed there really not all that hard. The replacement valve will not look the same or wire the same as the original. You will have to follow the wiring diagram to a tee. You have made it this far, but if you don't feel comfortable with doing it call in the pro's. Let me know if I can help further.
Rusty
#CARRIERMAN is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 02:24 AM
Furnace won't light Babybird HVAC 2 03-30-2007 10:48 AM
Bryant gas furnace non startup homer12 HVAC 4 12-14-2006 09:30 PM
