Bryant Furnace Troubles - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-21-2010, 05:35 PM   #16
God! I gotta get up to date on this carrier 2stg stuff.....
hvaclover is offline   Reply With Quote
Old 09-21-2010, 06:14 PM   #17
Hvac Pro
yuri's Avatar
Rewards Points: 376
Where ya been living? under a rock. They had that technology since the late 90's. LOL
Old 09-21-2010, 06:20 PM   #18
Hvac Pro
yuri's Avatar
Rewards Points: 376
Lots of interesting stories with these:http://www.docs.hvacpartners.com/idc.../58tua-9pd.pdf
Old 09-21-2010, 06:38 PM   #19
Yuri, Mi is the #2 state in the nation for the number of annual furnace change out.
The majority of the furnaces sold are not Carrier and Lennox. Armstrong, ICP (Arocaaire, Heil, Tempstar) Nordyne(Westinghouse, Gibson, Kelvinator, Tappan,)Ducane, Nordyen, Weathrking, York, Coleman, Luxaire, have the most market share. That's what my market consists of. Don't get me wrong, A two stage VS comes my way I tackle it. It might take a few calla to my friends in the business but it gets done. I hate getting parts for the things cause what I pay for a Carrier part varies with who is at the counter.
Old 09-21-2010, 06:50 PM   #20
Hvac Pro
yuri's Avatar
Rewards Points: 376
It is getting so complicated and high tech that VERY VERY few DIYers and unskilled techs will ever figure out the new mod furnaces or even the ECM drive units. You can change every single part in a G71 or SLP and w/o knowing how it really works (off draft/vacuum) be able to figure it out. I may have to live on to 75 as a consultant with the way the young guys are learnin.
Guess I am going to have the same problem if I buy one of them new fangled Ford Escapes with speed sensitive steering Yada yada yada
Old 09-21-2010, 06:53 PM   #21
An old Tradesmen
Rewards Points: 8,144
Some of these guys coming out of tech schools almost sound like they think if they get their NATE card. They can fix anything just by pulling it out.
Old 09-21-2010, 07:00 PM   #22
Hvac Pro
yuri's Avatar
Rewards Points: 376
Yep, first thing they do is buy the most expensive Fluke testers, digital superheat gauges etc etc. Blind leading the blind. Can't blame the schools though. No way they can teach them about undersized/oversized/mismatched systems/undersized ductwork/venting problems etc etc.
Old 09-21-2010, 07:02 PM   #23
Originally Posted by beenthere View Post
some of these guys coming out of tech schools almost sound like they think if they get their nate card. They can fix anything just by pulling it out.
nate????
Aaaarrrgggghhh
don't get me started on that money grubbing organization!!!!
Old 09-21-2010, 07:08 PM   #24
Go into a class and try to get across the text book definition to relative humidity.
You'll hear crickets chirping.
Old 09-21-2010, 07:10 PM   #25
bryant furnace troubles
Yuri:
Dumb question but I gotta ask.Is there any damage that could be done to the furnace unit if it only runs in low heat and never goes to high heat? Over time that is.
Thanks again.
Basics is offline   Reply With Quote
Old 09-21-2010, 07:14 PM   #26
An old Tradesmen
We're gonna grade you on your answer Yuri.
Old 09-21-2010, 07:16 PM   #27
Hvac Pro
yuri's Avatar
Rewards Points: 376
Not really. It adjusts the blower and inducer fan speed to give you the proper temp rise/combustion. Read the manual in:http://www.docs.hvacpartners.com/idc...i355b-40-3.pdf
page 49 it has the meter clocking method so you can check to see if it is in high fire that way instead of probing with your meter. Have not had problems with them not switching stages. It will average the cycles so you never really know when that time point is. A 2 stage tstat (need another wire) is more accurate and responsive. DIP switches need changing on the board if you have one of them installed.
Old 09-21-2010, 07:18 PM   #28
Hvac Pro
yuri's Avatar
Rewards Points: 376
We can get into a steady state combustion discussion but my old head aches now.
Old 09-21-2010, 07:27 PM   #29
HVAC / Plumbing
I'll give an A
without knowing the heat value & I used this method of clocking & it works.. 3600 x dial size ( hand on the meter) divided by seconds per revolution .. This is with no other gas appliances in operation
kenmac is offline   Reply With Quote
Old 09-21-2010, 07:31 PM   #30
An old Tradesmen
All the furnaces I checked or set up this last week with my CA were at 87% efficiency.
My oxygen sensor died.
I had to use a back up CA. It doesn't respond as fast as mine. So I would use mine first for diagnostics, and then the back up to fine tune.
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 01:24 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 08:56 AM
Bryant +80 Gas Furnace won't light tr0910 HVAC 4 01-14-2009 07:11 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
