Bryant Furnace Repair Opinions Needed - HVAC - DIY Chatroom Home Improvement Forum
Old 10-02-2013, 06:59 PM   #1
Rewards Points: 14
I recently replaced a Hot Surface Ignitor on my Bryant Induced Combustion Gas Furnace with electronic ignition, that was manufactured in 2002. Unfortunately, the spacing distance of the 2 wires in relation to the bracket was not the same as the old ignitor. As a result, one wire came in close contact with the bracket after installation and when the furnace was activated, there was a pop, spark, followed by a system shut down. Red LED is in continuous blink mode. Blower motor works but nothing else. Is it possible I blew the circuit control board?
Mitch3306 is offline   Reply With Quote
Old 10-02-2013, 10:32 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,826
Yep, one of my apprentices did the same thing.
Sorry.
The Following User Says Thank You to yuri For This Useful Post:
Mitch3306 (10-02-2013)
Old 10-02-2013, 11:05 PM   #3
Rewards Points: 14
Sorry.
It is possible that the new hot surface igniter is still good though? Element is still intact.
Old 10-02-2013, 11:11 PM   #4
Rewards Points: 616
that is quite possible...
carmon is offline   Reply With Quote
Old 10-03-2013, 08:09 AM   #5
Hvac Pro
yuri's Avatar
use an ohm meter 2 check it. should be around 50-60 ohms.
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
16-year old Bryant Plus-90 furnace phillip9 HVAC 5 03-05-2013 01:11 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 01:24 AM
Bryant 350MAV Furnace Code 31 Failure maq0 HVAC 0 10-10-2011 02:07 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
