Bryant Furnace Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 10-30-2012, 08:23 AM   #1
Bryant furnace problems
I'm getting a code 14 which is for the flame sensor but is it common for blower motor to continually run even with the wall switch in the off position
basicfracie is offline   Reply With Quote
Old 10-30-2012, 03:35 PM   #2
An old Tradesmen
Rewards Points: 8,176
Is the fan switch in the on position.
Old 10-30-2012, 04:51 PM   #3
No it's In the auto position
Old 10-30-2012, 05:24 PM   #4
An old Tradesmen
May have a short in the thermostat wiring.
Old 10-30-2012, 09:51 PM   #5
how
Rewards Points: 1,104
When you are saying "wall switch" are you meaning the power switch for the furnace or a thermostat?
how is offline   Reply With Quote
Old 10-30-2012, 10:12 PM   #6
Meaning where I can adjust the temperature setting
Old 10-30-2012, 11:12 PM   #7
how
If you remove the thermostat wire from the furnace connection "G" and the fan stops, then you've got a problem with the thermostat or the stat wiring.
If the fan continues running then I'd start checking the safety roll out or limit switches.
Old 10-31-2012, 11:10 AM   #8
Rewards Points: 446
The fan is more than likely running all of the time because of the issue with the flame sensor. The purpose of the fan running all the time is basically to get your attention that the furnace needs attention, that something is wrong. This is normal for the Bryant furnaces.
Have a service company over to resolve the issue and check out the entire furnace.
old_squid is offline   Reply With Quote
Old 11-01-2012, 09:31 AM   #9
Thanks for all the help. I unplugged the g wire at circuit board fan can off. Hooked it back up then fan came back on. Pulled wall thermostat fan went off. I replaced the wall thermostat and every thing is working normal. Thanks for all the help
The Following User Says Thank You to basicfracie For This Useful Post:
ben's plumbing (11-01-2012)
Lennox Furnace problems boolean HVAC 21 11-19-2012 06:45 PM
Carrier Gas Furnace - Problems with Ignition jean004 HVAC 33 01-17-2012 01:26 AM
Test for Bryant furnace control center? nina01 HVAC 3 03-27-2009 10:02 PM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 08:56 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
