Old 05-31-2009, 09:16 AM   #1
DGB
Bryant Furnace pilot not lighting
I'm new here and not sure if I posted in the right forum.
Ok...here goes.
Bryant model BW2AAN000105ABAA another number I saw was PWB-4D. It's a gas hot water furnace.
The pump will circulate the water in the system, but the pilot light won't light thus no heat will be produced by the furnace. I thought it might be the auto pilot ignition box so I replaced that, but that didn't work. I was reading on the info. hanging on the wires of the furnace about it having a fuse that can blow when the flame in furnace gets blowed hard on. (had a huge wind storm here a couple weeks ago knocking down tree's all over the place and that seems to be around the time the furnace wasn't making heat. I just thought that it was warmer that it wasn't kicking on). Possibly a gust of wind came down causing the flame to get blown in such a way as a safety the fuse blew like it was designed to do.
What does this fuse look like and where is it located. I found a little device that is whitish/ivory looking (inside the little door you take off to see the burners) with 2 wires attaching to the top and what looks like a capacitor or resistor going across the bottom of where the two top wires attach to.
Any other suggestions would be appreciated.
DGB is offline   Reply With Quote
Old 05-31-2009, 12:15 PM   #2
I have a forced hot air bryant gas furnace that wouldn't start. It would fire up for a second then turn off. There was an error light on the control board as well.
Turned out, a bee had become stuck on the gas jet and died. The furnace was detecting a gas flow problem and turning off. I removed the bee and it's been working fine since.
Sound like yours isn't even igniting.
This is the best manual online I can find for your model: http://www.docs.hvacpartners.com/idc...og-bs1a-03.pdf
I did find a recall for your model: http://www.general.hvacpartners.com/...73_LID,00.html
KHouse75 is offline   Reply With Quote
Old 05-31-2009, 12:47 PM   #3
DGB
Thanks for the links .
Bryant 394J Furnace - Pilot stays ON all the time Davexxx HVAC 17 04-08-2012 07:46 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 02:24 AM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 09:56 AM
Bryant +80 Gas Furnace won't light tr0910 HVAC 4 01-14-2009 08:11 AM
Pilot light button on furnace won't turn whydonchathen HVAC 5 10-06-2008 12:03 AM
