Bryant Furnace pilot not lighting
I'm new here and not sure if I posted in the right forum.
Ok...here goes. Bryant model BW2AAN000105ABAA another number I saw was PWB-4D. It's a gas hot water furnace. The pump will circulate the water in the system, but the pilot light won't light thus no heat will be produced by the furnace. I thought it might be the auto pilot ignition box so I replaced that, but that didn't work. I was reading on the info. hanging on the wires of the furnace about it having a fuse that can blow when the flame in furnace gets blowed hard on. (had a huge wind storm here a couple weeks ago knocking down tree's all over the place and that seems to be around the time the furnace wasn't making heat. I just thought that it was warmer that it wasn't kicking on). Possibly a gust of wind came down causing the flame to get blown in such a way as a safety the fuse blew like it was designed to do. What does this fuse look like and where is it located. I found a little device that is whitish/ivory looking (inside the little door you take off to see the burners) with 2 wires attaching to the top and what looks like a capacitor or resistor going across the bottom of where the two top wires attach to. Any other suggestions would be appreciated. |
I have a forced hot air bryant gas furnace that wouldn't start. It would fire up for a second then turn off. There was an error light on the control board as well.
Turned out, a bee had become stuck on the gas jet and died. The furnace was detecting a gas flow problem and turning off. I removed the bee and it's been working fine since. Sound like yours isn't even igniting. This is the best manual online I can find for your model: http://www.docs.hvacpartners.com/idc...og-bs1a-03.pdf I did find a recall for your model: http://www.general.hvacpartners.com/...73_LID,00.html |
Thanks for the links :).
| All times are GMT -4. The time now is 04:39 PM. |
