Bryant Furnace Model 383K NO HEAT. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-01-2009, 10:33 AM   #1
My furnace has the red light blinking rapidly without a pause. The manual says to: Check for correct line voltage polarity. If units are twinned, check for proper low-voltage (24v) transformer phasing.
Any idea's what this means, where do I start. It has been in service for 9 years trouble free, how would the polarity change? Any help would be greatly appreciated.
bgeise is offline   Reply With Quote
Old 10-01-2009, 12:45 PM   #2
I have seen this several times with bryant and carrier furnaces. You are more than likely going to need a new circuit board.
SKIP4661 is offline   Reply With Quote
Old 10-02-2009, 08:50 AM   #3
Updated info.
I was trying to trouble shoot it last night and found that there was no voltage coming out of the board to the pressure sensor. When I went to the service department to purchase a new board they said did I check my transformer power output? I don't get any power on the volt meter, but if I disconnect it from my board the furnace fan will not run. Plug it back into the board and the fan will work. The board is $284.00 plus tax so I don't want to purchase it if that is not the problem.
Tags
383k , no heat , twinned , voltage polarity
BRRRR! NO HEAT! PLEASE HELP! Old Carrier Furnace! joeraccio HVAC 6 10-11-2010 10:07 PM
Test for Bryant furnace control center? nina01 HVAC 3 03-27-2009 11:02 PM
Bryant gas furnace internal water leak.... naexec HVAC 6 11-25-2008 01:40 AM
CARRIER 58RAV Furnace Blows Cold Air-No Heat sarosie HVAC 2 12-05-2007 01:00 AM
