Bryant Furnace Lock Out - HVAC - DIY Chatroom Home Improvement Forum
Old 01-14-2008, 10:06 AM   #1
I have a Bryant model 383K gas furnace. When call heat is on, furnace will go through one cycle and then give codes 14, 31 and 33. I have replaced heat sensor, ignitor and put in new filter. Normally only does this when it is rather cold outside. Also recently put in new blower assembly. any ideas why it will only run one cycle before locking out?
DADDY31 is offline   Reply With Quote
Old 01-14-2008, 04:43 PM   #2
Union HVAC Tech.
Is the rotation on the blower motor correct?
bigMikeB is offline   Reply With Quote
Old 01-14-2008, 06:14 PM   #3
Yes it is correct.
Old 01-15-2008, 07:20 AM   #4
Union HVAC Tech.
There should be a chart on the inside of the blower door with the error codes for that unit.
Old 01-15-2008, 07:33 AM   #5
i have the codes, was just trying to narrow it down a bit to repair.
Old 01-19-2009, 12:05 AM   #6
I have the same furance and problems. It always seems to happen when its really cold. This is the second year I have had a code 31 right after a 10 below zero night. I always make sure the filter is new and furance is clean. Than I turn the power off at the furance for about an hour to clear the circuts. Once I turn the power back on it seems to work fine until the next really cold night. Go figure.
MikeIL is offline   Reply With Quote
Old 01-19-2009, 02:27 AM   #7
you might have mentioned what the codes mean even we have to read them sometimes
kennzz05 is offline   Reply With Quote
Old 01-19-2009, 05:47 PM   #8
Well Kenn, according to the manual and I quote "Each of the following status codes ia a two digit number with the first digit determined by the number of short flashes and the second digit by the number of long flashes" If you need the LED code for the above I will be happy to scan it and send it to you.
Old 01-21-2009, 11:21 AM   #9
what does your manual say a 14,33 and whatever the last one was? just saying its throwing codes isnt helpful sorry i didnt make myself clear originally
Old 01-25-2009, 01:04 PM   #10
It is either: Pressure, Draft Safeguard or Auxiliary-Limit Switches.
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 02:24 AM
Bryant furnace won't stop clicking RichA HVAC 1 12-31-2007 03:41 PM
Burner on Bryant furnace won't come on Flylowflyslow HVAC 1 09-19-2007 01:57 PM
bryant furnace will not light somany?'s HVAC 16 11-29-2006 09:28 PM
