Old 11-03-2011, 04:16 AM   #1
Bryant furnace fan
Bryant furnace (older) heats to the set temperature, but fan then does not stop running. What is the function of the power(?) button which pops out when the panel to change the filter is removed-mine was taped to remain pushed in.
dnspencer is offline   Reply With Quote
Old 11-03-2011, 07:57 AM   #2
biggles's Avatar
Bryant furnace fan
it is a safty for you when reaching in and around the fan...and if the system is on heating or cooling.....check your setting on the stat make sure the FAN is in AUTO setting.question...is the fan running with low/med air sound or hi fan as if it was summer running?
16-year old Bryant Plus-90 furnace phillip9 HVAC 5 03-05-2013 02:11 PM
Bryant Furnace Blower Won't Shut Off aorozco HVAC 3 12-02-2010 02:20 AM
air cycler install for bryant 90 gas furnace bill c Electrical 1 10-29-2010 10:53 AM
Bryant Furnace pilot not lighting DGB HVAC 2 05-31-2009 12:47 PM
Bryant gas furnace internal water leak.... naexec HVAC 6 11-25-2008 01:40 AM
