Bryant Furnace Blower Won't Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 11-30-2010, 10:27 AM   #1
Unhappy
My problem started about a month ago. I had the heat on in my house and noticed that one night my blower stayed on even though the temperature in my house was above what I set the thermostat to shut off at. Only room temperature/cool air was coming out of my vents. I called a friend who told me that my thermostat may have gone bad, what I found odd is that every now and again it would work properly, shut off and turn on according to the program I had set. But I took his advice and bought a new thermostat. When I took off the old one there were 5 cables, White, Green, Red, Yellow, Blue. They were all connected except for the blue one. So I connected my new one exactly as the old one was connected and it worked for about a day and then the blower went back to staying on. Also, when I took the cover off the furnace the blue wire was wrapped around itself and not connected to anything. My furnace is a Bryant brand and looks to be about 2 decades old but I'm not sure. I've attached pics of what I think may be useful and any help would be great!!!
aorozco is offline   Reply With Quote
Old 11-30-2010, 12:18 PM   #2
HVAC / Plumbing
sounds like you may have a fan relay that's sticking keeping the fan on.. The blue wire is probably a common wire. Required to be connected for some thermostats
kenmac is offline   Reply With Quote
Old 11-30-2010, 04:34 PM   #3
An old Tradesmen
Rewards Points: 6,906
Or a dirty air filter, and the limit is tripping and causing the fan to continue to run.
Old 12-02-2010, 01:20 AM   #4
I've changed the air filter several times. Would a cheap air filter be a potential cause of this? As for the possible stuck relay, how do I go about testing it and would it most likely be behind that metal box in the top two pictures?
The blower on my Lennox furnace won't shut off kgduda HVAC 8 10-31-2010 01:31 PM
Trane furnace runs even after burners shut off smb2 HVAC 3 01-10-2010 08:16 AM
How much power does a small furnace blower use? Red Squirrel HVAC 10 07-31-2009 09:03 PM
Bryant Furnace pilot not lighting DGB HVAC 2 05-31-2009 11:47 AM
Furnace blower not working right. oiljumper HVAC 4 11-10-2008 10:22 PM
