Bryant Furnace Blower Running Constantly - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-30-2008, 09:08 PM   #16
The 821 is not the heat cool relay. From what you are telling me, I think that you have the following: Power goes to the common of the heat cool relay, a wire from the NC terminal goes to the 821 relay power contact and from there to the medium high speed of the blower motor. A wire from the NO terminal of the heat cool relay goes directly to the high speed of the blower motor. When the furnace is running in heat mode, power passes through the NC of the heat cool relay to the 821 which will make after a delay when the gas valve is on and the blower runs on medium high. In A/C mode, 24 volts is applied to the coil of the heat cool relay which picks up and puts power from the NO terminal to high speed. If either relay sticks, the fan will continue to run. To find out which one, just pull off the wires, one at a time, to the motor.
hoistdoctor is offline   Reply With Quote
Bryant 355MAV furnace and A/C blower not starting rajar2 HVAC 39 11-05-2015 01:03 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 01:24 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
furnace blower constantly running HELP! ice_wolf69 HVAC 16 10-26-2008 06:11 PM
furnace blower keeps running dmbrasket@hotmail.com HVAC 7 02-03-2008 03:57 PM
