Bryant Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 05:11 PM   #1
bryant furnace
have a bryant 350mav036080 furnace. intermittent trouble firing. gas pressure is good, hsi is good,cleaned flame sensor. sometimes it works fine, sometimes it goes into ignition failure lockout. reset by turning power off and back on. is this a common problem? maybe the board?
hertaylo is offline   Reply With Quote
Old 11-30-2011, 05:15 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,318
are you a tech? burners may be dirty and need removing and cleaning. flush them with hot water in a sink and blow them out with air. crossovers may be dirty. check where the intake pipe attaches to the burner box. inside is a screen on some models and it can get plugged with leaves/debris. if it has a concentric kit then check the intake carefully, can get spiders webs and debris in there.
Old 11-30-2011, 05:19 PM   #3
i am a tech. i've run into this intermittent trouble a few times before and it was in the board. not familiar with common bryant problems. some brands have their little tics
Old 11-30-2011, 05:32 PM   #4
What fault code are you getting?
harleyrider is offline   Reply With Quote
Old 11-30-2011, 06:03 PM   #5
Hvac Pro
yuri's Avatar
Yeah, get us the code and check all those points I gave you. I have worked on lots of those units. Not had a lot of problems with their boards, unlike the mids of brand C.
16-year old Bryant Plus-90 furnace phillip9 HVAC 5 03-05-2013 01:11 PM
Bryant Furnace Blower Won't Shut Off aorozco HVAC 3 12-02-2010 01:20 AM
air cycler install for bryant 90 gas furnace bill c Electrical 1 10-29-2010 09:53 AM
Bryant Furnace pilot not lighting DGB HVAC 2 05-31-2009 11:47 AM
Bryant gas furnace internal water leak.... naexec HVAC 6 11-25-2008 12:40 AM
