Bryant Evolution Thermostat - Displayed Temp Is +2 Degree Higher Than Room Temp? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-15-2011, 01:59 PM   #1
Bryant Evolution Thermostat - displayed temp is +2 degree higher than room temp?
I have a new Bryant Evolution system with the Evolution control thermostat. The temperature displayed on the thermostat is 2-3 degrees higher than the actual room temperature as measured by several standalone thermometers. Is there a way to adjust the Evolution thermostat to compensate for the temperature difference so it displays the actual room temperature? Thanks
hylton5 is offline   Reply With Quote
Old 01-15-2011, 02:58 PM   #2
Yes, this can be done in the advanced/service menu.
Press and hold the advanced button for 10-seconds until the service menu appears.
Select setup
Select thermostat
Select offsets
Select room temp offset
Adjust this as necessary
All aspects of the Evolution control including the service menu can be found here:
http://www.docs.hvacpartners.com/idc...iuid01-0-1.pdf
civiltoatee is offline   Reply With Quote
Old 01-15-2011, 05:28 PM   #3
An old Tradesmen
Rewards Points: 7,370
Seal the hole in the wall where the wires come through before adjusting display temp.
Bryant Evolution Thermostat - Programming MNHouse HVAC 3 11-26-2010 09:19 AM
Bryant Evolution Thermostat: Installation & Programming NickE1963 HVAC 6 01-27-2009 03:57 PM
