Bryant Error Code 25 - HVAC - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 10:58 AM   #1
Rewards Points: 150
Bryant error code 25
My furnace would run for a couple seconds and then kick off. I figured it was the flame sensor so I took it out and cleaned it. I also took out the ignitor and cleaned it too. Now when I power it back on I get the 2 flashes followed by 5, so I am guessing that is error code 25. It won't even kick on now. Does anyone know what error code 25 is for a Bryant Evolution Plus 90i. I have googled it, but haven't really found anything specific for that code.
Any help is much appreciated and Thank you!!
Abs777 is offline   Reply With Quote
Old 04-22-2013, 11:02 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
there should be a legend on the inside of the service doors or on the inside of the furnace itself.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
Abs777 (04-22-2013)
Old 04-22-2013, 12:38 PM   #3
Rewards Points: 150
Thank you Doc. I will check it out this evening when I get home.
Old 04-25-2013, 01:26 PM   #4
Rewards Points: 150
I checked it out and it says it is a setup error - indicates that the model plug is missing or incorrect or setup switch "SW1-1" or "SW1-6" is positioned improperly. I checked the switches and they are fine. I removed the model plug a couple times and reinstalled and then it started working, but that lasted one day and it is erroring out again with the same code. Could the model plug be bad? It's just a little circuit board with two resisters on it. I checked the continuity on them and it looks like they both are not letting any current through.
Could that be it?
Thanks!
Old 04-25-2013, 03:08 PM   #5
I'm having trouble understanding what a model plug is, never heard of it before.
Thanks.
Old 04-25-2013, 07:29 PM   #6
An old Tradesmen
Rewards Points: 6,476
Used to tell an Infinity/Evolution furnace replacement board what model furnace it is controlling.
Yes, it could be bad. Also, you should never, never clean a HSI, it tends to ruin them.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (04-26-2013)
Old 04-25-2013, 11:26 PM   #7
thank you sir. as always, I'm always listening to you, learning
Thanks.
Old 04-26-2013, 12:12 AM   #8
Experienced HVAC Tech
HVAC1000's Avatar
how did you determine no current was going through the resistors?
HVAC1000 is offline   Reply With Quote
Old 05-03-2013, 07:16 AM   #9
Rewards Points: 150
I replied awhile ago, but it didn't take it I see.
Thanks Beenthere I did not know that and I won't clean it again.
HVAC1000 - I checked it with my multimeter.
Weird think happened, I took the model plug out and with me for the day to see if I could any place that sold them. I called the company that put it in when the house was built eight years ago. They said they have never seen a model plug go bad and that more than likely it was the system board. They would sell it to me for $650, but it wouldn't have a warranty. They said I should let one of their techs come out for $75 and let him diagnose it, then if that is what it is he would install it and it would then have a year warranty. By the time everything is said and done it will be $900+. I just hate paying that much more if I could do it myself. So anyway I go home and plug in the old one and it fires up and has been working ever since. No idea what is up.
Old 05-03-2013, 11:22 AM   #10
HVAC1000's Avatar
Thanks I figured you would use something like that.
The intention of my question was how did u read the current in the circuit. The only ways to do that are either break the circuit and put your meter in series or use an amp clamp which I just as much doubt you were able to get on one of those resistors
Old 05-03-2013, 01:51 PM   #11
Rewards Points: 150
I put the leads on each side of the resistor and checked the ohms.
Bryant evaporator coil and using A/C sealant. tampaite HVAC 14 04-19-2013 07:40 AM
Heat pump (Bryant) in CT? desmo907 HVAC 7 07-16-2012 08:09 PM
Bryant Plus 90 giving code 24 error even when wired? nsurg HVAC 2 06-19-2011 12:26 AM
Bryant Warranteed heat exchangers issues TruckTahoe HVAC 0 02-14-2011 03:21 PM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 09:56 AM
