Bryant Draft/vent Rollout Switch Testing - HVAC - DIY Chatroom Home Improvement Forum
Old 11-19-2013, 09:11 AM   #1
Bryant draft/vent rollout switch testing
I have a no fire issue with a Bryant model 376CAVO3670 horizontal unit. I have chased the ignition circuit to the draft rollout switch that trips: a manual reset of this switch allows the unit to fire and run for one cycle. The unit does not "seem" hot during this cycle...makes me think the rollout switch is bad.
I will check exterior vents this weekend for an obstruction, but don't think this is the problem.
Question: should this switch reset itself after tripping? Any way to test for reset?
Question: Any recommendations for cleaning flue? Shop vac and dryer vent brush?
Thanks for any help!
Mark Stanfield is offline   Reply With Quote
Old 11-19-2013, 11:39 AM   #2
as seen on tv
Rewards Points: 150
pull the inducer fan check the wheel and clean the housing then inspect the vent and test the draft
qbert is offline   Reply With Quote
The Following User Says Thank You to qbert For This Useful Post:
plummen (11-19-2013)
Old 11-19-2013, 05:53 PM   #3
An old Tradesmen
Rewards Points: 6,060
If the wheel is clean, then the problem usually turns up to be in the vent/chimney. could be the chimney cap is bad and restricting the chimney.
The Following User Says Thank You to beenthere For This Useful Post:
A few wiring questions on installing this timer switch thinksincode Electrical 19 03-04-2013 06:31 AM
Bryant Furnace Pressure Switch Problem dmichel HVAC 6 02-12-2013 04:43 PM
Diagram for 3 way ceiling fan light switch Aurora65 Electrical 22 11-27-2012 10:11 AM
Bryant 311AAZ036070 Limit Switch Problem coleary61385 HVAC 5 02-24-2012 06:01 PM
Safety Rollout switch issues DannyV HVAC 3 02-18-2011 12:09 PM
