Bryant Code 31 - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-30-2006, 06:13 PM   #16
Well I thought older units did not have a stainless steel cover.I could be wrong time flys by fast in the heating buisness.Maybe it was longer ago than that.I was only trying to added to the posible problems that the furnace may have had,not trying to say this was the answer.sounds like a lot of good techs in here.
trollmastergeneral is offline   Reply With Quote
Old 12-28-2010, 09:31 PM   #17
I have a code 31 too.
I have a code 31 on my furnace. It starts then stops after several seconds. This is not a pressure switch related issue. The pressure switch it not open when the unit fails. I even held it in manually for a few minutes and the unit still starts and stops on its own. Any Advice?
markebenson is offline   Reply With Quote
Old 01-05-2011, 04:20 AM   #18
K it ended up being the control pcb. I got one on ebay for $55. They have many more available if anyone else gets the same problem.
EVERYONE HERE HAS BEEN TALKING ABOUT THE PRESSURE SWITCH RELATED ISSUES. Watch the pressure switch to see if it deactivates before the unit fails. If the pressure swich cuts off AFTER AND NOT BEFORE the fan, furnace, etc cuts off, there is really no other components I see that can cause this problem other than the pcb. It fixed my problem!
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 10:19 AM
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 02:57 PM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 01:47 PM
code question JustJoe Building & Construction 3 01-27-2007 09:06 AM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
