Bryant/Carrier Start Relay - HVAC - DIY Chatroom Home Improvement Forum
Old 07-26-2009, 10:52 PM   #1
Last year my Bryant ACís contactor started sparking / chattering and eventually burned out. While inspecting it, Iíve also noticed a leaked start capacitor, so figuring it was the culprit, Iíve replaced them both and the AC ran fine for a few months until the fall. This year the new contactor is at it again Ė sparks and keeps failing to hold (but eventually does after a dozen of intermittent tries). This time I figured I should go for a start relay / capacitor combo, but trouble is Ė I canít find this specific relay anywhere. Carrier part # is HN61HB540 (GEís 3ARR3BL3P5), but when I search for it online I only come across PDFs referencing some KSAHS ďstart capacitor/ relay kitsĒ, but nobodyís actually selling them, nor separate relays. Can a Carrier/Bryant expert please recommend a substitute?
Any tips will be greatly appreciated!
neWave
neWave is offline   Reply With Quote
Old 07-26-2009, 11:05 PM   #2
as seen on tv
Rewards Points: 150
If the contacter is chattering sounds like you have a voltage drop somewhere in the line. High pressure or low pressure switch bare low voltage line. I would think the parts you are replacing is just the end result of the underlying problem.
qbert is offline   Reply With Quote
Old 07-27-2009, 02:27 AM   #3
So in that case, where would you suggest to look upstream? Could the AC be wired incorrecty, or is it the overall load on the house? Intermittency of this issue is what's most puzzling. Sometimes it starts and runs fine. Sometimes contacter sparks for a few times and then engages. And then sometimes it'll be suffering multiple chatter attacks with periods of inoperable silence inbetween, completely failing to maintain contact.
Old 07-27-2009, 08:36 AM   #4
hvaclover's Avatar
Somewhere between the indoor and out door unit the may be a nick or crimp in the control wire.
Could also be a loose connection at the furnace/airhandeler or the the thermostat.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 07-27-2009, 09:01 AM   #5
Measure the nominal 240v going into the unit right at the unit; if it changes more than 3% or 5% between the unit running normally and when the unit is switched off there is a high resistance upstream.
How long of what size alum. or copper wire runs to the unit?
Well pump noisy, tripping overload. lennyjay Electrical 2 07-07-2009 11:47 AM
Brand new PAYNE PG9MAB won't start . Error code 12 tp618 HVAC 3 12-19-2008 10:21 PM
Blue smoke at start up, and shudder at idle fauer Automotive Repairs 6 08-22-2008 12:39 PM
newbie...relay problems jfabes Electrical 11 05-06-2008 05:48 PM
