Bryant/Carrier Relay Or Board - HVAC - DIY Chatroom Home Improvement Forum
Old 08-05-2010, 05:44 PM   #1
Bryant/Carrier relay or board
So I have an old bryant unit that my friend says the relay is bad (AC will not kick on or even make a noise when it should be firing up). In the interim my friend bypassed the relay to make it work. I found a screen show of the board and unit I own, for you all to take a look. Now can I get just a relay, or do I need a whole new board? Some feel that the whole board requires replacement. Here is the screen shot, and all the information I could get off that old unit since some of it was too faded.
Bryant labelled (carrier on tag inside)
Model: 394calc24050
50,000 btu an hour
Serial: 4986a03900
Electric panel: 306022-201 rev A
Cool relay: 728-0016 2Frelay
DAdams982 is offline   Reply With Quote
Old 08-05-2010, 06:18 PM   #2
HvacWiz's Avatar
Rewards Points: 252
You will need to replace the board.
HvacWiz is offline   Reply With Quote
Old 08-05-2010, 06:37 PM   #3
Thank you for the information... any idea where I could find that model by chance?
Old 08-06-2010, 11:42 AM   #4
HvacWiz's Avatar
Rewards Points: 252
The upgraded board part # is HH84AA020
Old 08-06-2010, 01:21 PM   #5
Great... I went to purchase it online, but it didnt list my model number as a replacement.... at least on this website:
http://www.hvacpartsoutlet.com/carri...hh84aa020.aspx
Old 08-06-2010, 04:43 PM   #6
HvacWiz's Avatar
Rewards Points: 252
That is the correct board you will need.
The Following User Says Thank You to HvacWiz For This Useful Post:
DAdams982 (08-06-2010)
Old 08-06-2010, 07:09 PM   #7
Ordered... You sir are a good man.
Old 11-17-2014, 09:38 AM   #8
Rewards Points: 2
Thumbs up
HVAC problem
I have a similar problem with a Carrier unit that I believe that this solution will repair also. Thanks for the info. it has been very helpful. I appreciate the advice I have gain from your post to a fellow member. I am new to this forum but I am sure I will enjoy participating in it. I am a Machinist/Tool& Diemaker by Trade if I can be of help I will be glad too.
Whswrencher is offline   Reply With Quote
Old 11-18-2014, 08:17 AM   #9
We just replaced the same board on ours yesterday. Easy swap out.
kendon11 is offline   Reply With Quote
Bryant/Carrier Start Relay neWave HVAC 7 09-19-2015 11:33 PM
installing backer board over particle board bob mac Flooring 6 07-16-2013 03:15 PM
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 09:41 PM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 10:03 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
