Bryant 90 Plus Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-02-2010, 08:30 PM   #1
Bryant 90 plus furnace
Forced air blower stays on when I turned t-stat to heat for first time this season. Why?
vicecommander is offline   Reply With Quote
Old 10-02-2010, 08:31 PM   #2
are you getting heat?
hvaclover is offline   Reply With Quote
Old 10-02-2010, 08:35 PM   #3
No heat just cold air
Old 10-02-2010, 08:45 PM   #4
i'm no expert by anymeans.... but did you check to see if ur pilot was lit? or if the gas was turned on? i had that problem when i moved into my home lol they turned the gas off INSIDE the machine... not the remote kill switch.
dtiao7eb is offline   Reply With Quote
Old 10-02-2010, 09:08 PM   #5
HVAC / Plumbing
make sure you didn't accidently switch Fan on at the t.stat. you could also have an open limit somewhere, mis fire, bad hsi
kenmac is offline   Reply With Quote
Old 10-02-2010, 11:28 PM   #6
Ten bucks its a dirty sensor.....or filter
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 01:24 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 08:56 AM
Bryant +80 Gas Furnace won't light tr0910 HVAC 4 01-14-2009 07:11 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
