Bryant +80 Furnace Code 32 - HVAC - DIY Chatroom Home Improvement Forum
Old 02-18-2011, 09:38 PM   #1
Bryant +80 furnace code 32
Hi all, looking for help. My furnace has an intermittent problem, and when it won't run it flashes code 32 (label says to check for:proper vent sizing, low inducer volatage, defective inducer motor, excessive wind, inadequte combustion air, defective pressure switch) I had a tech come out and he said the inducer motor was bad. Replaced it, and the same problem. I've checked the pressure switches and tubing, they hold vacuum and the switches operate correctly--checked them on and off for continuity with multimeter.
I think the problem may be in the board because sometimes the inducer just comes on (less than a second) and the furnace shuts down. I hear a relay clicking when it does this. When the inducer actually runs it pulls down the pressure switches just fine, the ignitor comes on, lights the gas and then it will run for a while and shut down, flashing code 32.
I did take apart the flu and look down the chimney and it is all clear. The condensate drain is clear and no water.
Any suggestions?
shalenkur is offline   Reply With Quote
Bryant 355MAV furnace and A/C blower not starting rajar2 HVAC 39 11-05-2015 01:03 PM
Carrier furnace help code 13 mudtruck HVAC 10 11-23-2013 02:24 PM
Bryant 383KAV Furnace - Continuously Blowing Cold Air josh42bigO HVAC 0 12-01-2010 02:34 AM
Bryant 355MAV furnace Beaumont General DIY Discussions 8 10-22-2010 07:27 AM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 09:08 PM
