Bryant 395Cav Fires Up, But Does Not Blow Heat!! We're Freezing In Michigan, Help! - HVAC - DIY Chatroom Home Improvement Forum
Old 12-27-2010, 12:04 PM   #1
Bryant 395Cav fires up, but does not blow heat!! We're freezing in Michigan, help!
My Bryant 395cav will fire up but won't blow heat threw the vents. There's a buzzing sound and then nothing. What should we do? I have no money to call anyone to repair it.
goodmancj is offline   Reply With Quote
Old 12-27-2010, 12:11 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,092
Put your hand on the motor. Is it blazing hot? Try turn it to ON at tstat if you have AC.
Old 12-27-2010, 12:17 PM   #3
Experienced
Jackofall1's Avatar
Sounds by your description that the blower motor has failed and needs to be replaced.
Have you smelled burned wire insulation lately?
I think what Yuri is trying to say is turn the fan on manually at the tstat, and then feel the motor. I would first turn the switch off on the side of the furnace then turn the tstat to fan on manually, then go back and turn the switch on, on the side of the furnace.
When you remove the door over the fan compartment there is a limit switch that will have to be depressed in order for the fan to attempt running.
Old 12-27-2010, 12:21 PM   #4
We have smelled the smell of a furnace just turned on for the first time of the season. And what is a tstat?
Old 12-27-2010, 12:23 PM   #5
Experienced
Jackofall1's Avatar
Thermostat
Old 12-27-2010, 12:24 PM   #6
Experienced
Jackofall1's Avatar
Your motor on the main circulation fan is likely toasted, are you confident enough to replace it?
Depending on your unit size the motor will be 1/5 to 3/4 hp.
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 02:17 PM
vent sucks cool air instead of blow heat wayneled86 HVAC 3 01-25-2009 11:10 PM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
Blower Fires Up But No Heat, just Cold Air amyco33 HVAC 4 04-13-2008 08:33 PM
boiler fires but no heat janhuge HVAC 1 11-09-2007 05:52 PM
