Bryant 395c Furnice Gas Valve Will Not Open - HVAC - DIY Chatroom Home Improvement Forum
Old 10-03-2011, 10:04 AM   #1
Bryant 395c furnice gas valve will not open
Hi,
I have a Bryant 395c furnace. The gas valve will not open. It goes thru the start up. The hot surface igniter glows for several cycles, then goes out without the gas valve opening. The same thing happens on the test procedure. What is preventing the valve to open?
Thank you.
fazeklo is offline   Reply With Quote
Old 10-03-2011, 12:33 PM   #2
JJboy's Avatar
At the moment ignition is glow, you should have 24vac at gas valve. You need also do continuity test.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-03-2011, 04:24 PM   #3
Thanks for the answer. I have no voltage at the valve. How do I do a continuity test?
Old 10-03-2011, 04:35 PM   #4
JJboy's Avatar
The control board sends the 24vac to gas valve. Bad control board.
http://www.google.com/url?sa=t&sourc...OhUDaA&cad=rja
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 09:45 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 08:48 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
Can't reinstall shower valve properly ptoneil Plumbing 3 04-10-2008 11:05 PM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 11:46 PM
