Bryant 395BAW Won't Start - HVAC - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 12:10 AM   #1
Bryant 395BAW won't start
I have a 1985 Bryant central air Furnace model 395BAW048095 with a White Rogers 36E gas valve. The flue is metal and there is a fan within the furnace to create a vacume at the base of the flue pipe conection that turns on when a call for heat comes from the thermostat at startup to ignition. The spark fires but no gas is released by the valve for the pilot to lite. Added information: The blower fan is set to continually run, I replaced the pressure switch (306621) and the limit switch (HH12ZB180), and the circuit board burned out two years ago and I replaced it at that time with a Carrier HH84AA021, I replaced the blower motor three years ago. Any help would be appreciated.
saltyprof is offline   Reply With Quote
Old 09-23-2010, 04:20 AM   #2
An old Tradesmen
Rewards Points: 7,816
Is the gas valve getting voltage.
Old 09-23-2010, 08:40 PM   #3
How do I check the voltage? The wiring going into the valve control is
How do I check the incoming voltage? The incoming wiring to the gas valve is: Green to 5, 2 white to 1, brown to 4, 2 blue to 2 one of which is from 3, 2 blue to 3 one of which is from 2.
The gas valve is labeled EF32CB197A. Thanks for the help.
Old 09-23-2010, 08:43 PM   #4
An old Tradesmen
I'd need a pic to tell you over the net.
Tags
furnace , furnace repair , furnace repair help , furnace won't ignite , gas furnace problem
Bryant 355MAV furnace and A/C blower not starting rajar2 HVAC 39 11-05-2015 01:03 PM
Bryant 90i furnace won't start Crash629 HVAC 1 12-02-2009 05:20 PM
Brand new PAYNE PG9MAB won't start . Error code 12 tp618 HVAC 3 12-19-2008 09:21 PM
Blue smoke at start up, and shudder at idle fauer Automotive Repairs 6 08-22-2008 11:39 AM
Bryant Plus 90 start up problem mgraw HVAC 2 01-07-2008 05:54 PM
