Bryant 383kav - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-30-2012, 12:19 PM   #16
Originally Posted by Houston204 View Post
That sensor isn't much more than a bent nail with a porcelain base to insulate it from ground.
Does the field installed ground wire screw to the furnace body or wire nut to a green wire that runs to the burners?
If it screws to a 2 by 4 jbox in the furnace, verify that your jbox is making a clean contact with the furnace body.
Wire nut to green wire. I removed it, steel wooled it and the surface underneath.
When I steel wooled the sensor and replaced it, the furnace kicked on and heated normally until it cycled down and then blew only cold air when it came back on. After I restarted it I got the 34 code again after lockout.
gman5256 is offline   Reply With Quote
Old 11-05-2012, 10:36 AM   #17
My electrician friend tested everything he could with a Fluke meter. Proper readings from sensor, continuity to board. We mostly go back to the 34 code, but there were two occasions with an erratic flashing of the code light that didn't "compute". He thinks it's a problem with the circuit board. There are used ones on ebay for $65 and new ones are $180.
Old 11-05-2012, 02:02 PM   #18
Rewards Points: 582
I would not buy a used control board.....ben sr
Old 11-05-2012, 03:49 PM   #19
Thanks, Ben. I found a new one locally for for $125!
The Following User Says Thank You to gman5256 For This Useful Post:
ben's plumbing (11-05-2012)
Old 12-22-2012, 05:50 AM   #20
Bryant 383kav acting up again
Well, we replaced the circuit board at the 1st of Nov, and it's been working fine. But this morning it began making a lot of noise and would'nt stop even when we shut it down at the thermostat. Before turning off the heater at the main cutoff(downstairs) I listened to it up close and it seems the sound was coming from the little motor/box that has the drain on the outside of the furnace.
I'm hoping this will be a simple fix/drop in part, etc.
Old 12-22-2012, 07:37 AM   #21
There is no error code,,,light is continuous.
Old 12-22-2012, 05:28 PM   #22
FWIW...we eliminated the condensation pump/box and ran pvc pipe straight to the sump pump well.
Heat pump (Bryant) in CT? desmo907 HVAC 7 07-16-2012 07:09 PM
Bryant Warranteed heat exchangers issues TruckTahoe HVAC 0 02-14-2011 02:21 PM
Bryant 383KAV Furnace - Continuously Blowing Cold Air josh42bigO HVAC 0 12-01-2010 02:34 AM
Bryant Gas furnace 383KAV - No heat labrat HVAC 2 10-11-2009 11:11 PM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 08:56 AM
