Old 10-27-2012, 08:53 PM   #1
Bryant 383kav
Why does my heater work for a while then stop. The motor cycles back on then the burners won't light and it blows cold air
gman5256 is offline   Reply With Quote
Old 10-27-2012, 09:12 PM   #2
Bryant 383kav
what error code or the number of flashes on control are you getting ben sr
Old 10-27-2012, 09:19 PM   #3
Bryant 383kav
way more info please...that's like saying why do my feet hurt...
carmon is online now   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
ben's plumbing (10-27-2012)
Old 10-28-2012, 07:24 PM   #4
Bryant 383kav
Learning as I go here...error code is 34. I polished the sensor with steel wool and restarted. It ran fine until it cycled off and then came back on blowing only cold air. I shut it off, emptied the drain box, blew out the copper line til it was empty. Now it just tries 3 times to start and goes into lockout.
Old 10-28-2012, 07:29 PM   #5
Houston204's Avatar
Bryant 383kav
Do you still get the code 34 error?
Do you still get flame ignition before lockout?
Houston204 is offline   Reply With Quote
Old 10-28-2012, 07:32 PM   #6
Bryant 383kav
Yes, it ignites 3 time and then locks out. Still have 34 error code.
Old 10-28-2012, 07:43 PM   #7
Houston204's Avatar
Bryant 383kav
Verify that ground is connected to the furnace.
Clean the face of the burners that is exposed to flame with a small wire brush. Be careful not to touch the fragile hot surface ignitor.
Your furnace is looking for at least 1/2 of one millionth of an amp DC from that flame sensor. I usually measure 2.8 to 5 uA DC when cleaned.
The Following User Says Thank You to Houston204 For This Useful Post:
gman5256 (10-28-2012)
Old 10-28-2012, 09:21 PM   #8
Bryant 383kav
Thanks, Houston. I was looking at it today and I think I can pull the burners and clean them. The electrical testing is probably beyond my abilities, but I have a friend who is a Master Electrician. I'll take a closer look at the igniter while I'm at it. The sensor looks ok to me, but it is a little different color at the tip.
Old 10-29-2012, 12:26 AM   #9
Houston204's Avatar
Bryant 383kav
I scrub them in place. I remove the sensor to clean it. Verify that the porcelain base of the flame sensor isn't cracked.
Wiring a meter in series with the flame sensor is not difficult with the right meter.
Old 10-29-2012, 06:54 AM   #10
Bryant 383kav
I did pull the sensor to clean it. I used steel wool...would sandpaper be better?
I took the sensor with me to a supply store(they didn't have one in stock) and the "guy" said the sensor looked good...the base is shiny white and undamaged.
Old 10-29-2012, 08:16 AM   #11
Houston204's Avatar
Bryant 383kav
That flame sensor is only half of the circuit.
The circuit board sends voltage to the flame sensor and measures the amperage. The flame conducts the voltage to the furnace body (ground).
If the ground wire isn't making good clean contact with the burners through the small greenwire connected to the burners it can reduce the 3 millionths of one amp to less than .5 micro amps dc.
If I had a vacation day for every time that ground wasn't properly connected to a furnace, I'd be asleep now.
gman5256 (10-29-2012)
Old 10-29-2012, 12:59 PM   #12
Bryant 383kav
I pulled the ground and cleaned the contact and the surface where it attaches...there was no apparent corrosion. The igniter glows before the burners kick on. My electrician friend is going to measure the voltage at the sensor for me. I've heard that the sensor can be bad even though it looks ok.
Old 10-29-2012, 02:40 PM   #13
Houston204's Avatar
Bryant 383kav
That sensor isn't much more than a bent nail with a porcelain base to insulate it from ground.
Does the field installed ground wire screw to the furnace body or wire nut to a green wire that runs to the burners?
If it screws to a 2 by 4 jbox in the furnace, verify that your jbox is making a clean contact with the furnace body.
Old 10-29-2012, 09:00 PM   #14
Houston204's Avatar
Bryant 383kav
This example has the ground connected to a junction box.
This would be a good reading...
gman5256 (10-30-2012)
Old 10-30-2012, 01:14 PM   #15
Bryant 383kav
[QUOTE=Houston204;1040623]This example has the ground connected to a junction box.
[/QUOT
good pics and info
Heat pump (Bryant) in CT? desmo907 HVAC 7 07-16-2012 08:09 PM
Bryant Warranteed heat exchangers issues TruckTahoe HVAC 0 02-14-2011 03:21 PM
Bryant 383KAV Furnace - Continuously Blowing Cold Air josh42bigO HVAC 0 12-01-2010 03:34 AM
Bryant Gas furnace 383KAV - No heat labrat HVAC 2 10-12-2009 12:11 AM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 09:56 AM
