Bryant 355MAV Inducer Motor Won't Run - HVAC - DIY Chatroom Home Improvement Forum
Old 10-24-2012, 11:43 AM   #1
Bryant 355MAV Inducer Motor won't run
Checked variable speed furnace control for 115-vac across PL2-4 and NEUTRAL-L2. Voltmeter measures 110-vac. This was on the homes 1st floor furnace where the inducer motor will not start after the heat sequence is initiated and the blower motor runs.
Should only 110-vac instead of 115-vac cause the inducer motor to not start?
There is a second identical furnace and furnace controller in the home to heat the 2nd floor zones. The voltage is 121-vac when testing the voltage across the same PL2-4 and L2 terminals.
I do not understand why only 110-vac instead of 121-vac like on the other furnace controller.
I am thinking the inducer motor should start with 110-vac. Checked for obstructions and there are none. Motor turns freely.
Thank you in advance for any help you can offer.
christ2 is offline   Reply With Quote
Old 10-24-2012, 01:35 PM   #2
Just checked the PL 11-6 and PL11-12 voltage to the inducer motor. Getting 120-VAC directly to the motor at this point.
So, whatever the reason only measuring 100-VAC at the PL2-4 and NEUTRAL-L2 on the control board does not seem to affect getting 120-VAC at the inducer motor.
Beginning to believe defective motor. Going to try a few more diagnostic checks.
Probably will swap out identical motor from the 2nd floor furnace to replace what appears to be a defective inducer motor on the 1st floor furnace. Will be purchasing a new replacement inducer motor if the swapped out motor runs.
Old 10-24-2012, 07:25 PM   #3
No need to go through all that. The motor has voltage and is not working, that's good enough to call it shot.
Old 10-24-2012, 08:23 PM   #4
Rewards Points: 582
for sure if you have 120 volt at inducer motor with call for heat...check for loose connections....if all tight ..replace inducer...ben sr
Old 10-25-2012, 11:38 AM   #5
Thanks guys. I replaced the motor last night and all is well in wifey-land.
The Following User Says Thank You to christ2 For This Useful Post:
ben's plumbing (10-25-2012)
Bryant 355MAV furnace and A/C blower not starting rajar2 HVAC 39 11-05-2015 02:03 PM
New air inducer fan not working. Bryant gas pack. Slammy HVAC 5 10-18-2012 12:30 PM
Bryant furnace inducer starts then furnace locks out Bill412 HVAC 4 10-09-2012 01:13 AM
Bryant Plus 90 398AAZ inducer motor PCWilson HVAC 10 02-27-2011 05:55 PM
Bad Bryant Plus 90i inducer motor/unit? PJoe HVAC 0 12-28-2009 08:17 PM
