Bryant 355MAV Blower Dies After One Or Two Cycles In High Heat, Resets To Low Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 08:47 PM   #1
Bryant 355MAV blower dies after one or two cycles in high heat, resets to low heat
The blower works fine in low heat and will transition into high heat. It will do a cycle or two in high heat, but then when it tries the next cycle of high heat, it fires up fine, the blower comes on for maybe 30 sec, then it dies and code 41 displays (blower failed to reach 250 rpm or blower failed to communicate to variable speed furnace control). It resets itself and comes back on in low heat, beginning the process all over again (and making for a very long time to reach the set temp). Any ideas?
The system is a Bryant 355MAV furnace (installed 1997). Only major service to date has been a new ignitor and main board (about 4 or 5 years ago).
Thanks for your help.
KThomas is offline   Reply With Quote
Old 11-29-2010, 09:06 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
because this unit is variable speed I recommend a pro to check it out. it could be control board, wiring harness, vs module on end of blower motor, with out a tec-mate tool to properly check it out, it will be very hard to diagnose this though the use of this forum
hvactech126 is offline   Reply With Quote
Tags
355mav , blower shutdown , bryant , code 41
Bryant 355MAV furnace and A/C blower not starting rajar2 HVAC 39 11-05-2015 01:03 PM
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Rheem Criterion 2: high fan heat only dyincolor HVAC 2 03-27-2010 09:17 PM
