Bryant 350mav - HVAC - DIY Chatroom Home Improvement Forum
Old 11-06-2011, 04:00 PM   #1
bryant 350mav
my furnace just kind of kicks on and runs whenever it wants the thermostate is set at 65 and its 69 in the house and it wants to run any ideas on what my problem might be?
scottsyring is offline   Reply With Quote
Old 11-06-2011, 04:59 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
on call for cool I'm taking it?
Doc Holliday is offline   Reply With Quote
Old 11-06-2011, 05:01 PM   #3
well its on call for heat
Old 11-06-2011, 05:03 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,108
What type of thermostat do you have. If it is an older electronic or el cheapo those can cause problems especially the power stealing type. Buy a good Honeywell Focus Pro from HDepot and try it instead.
Old 11-06-2011, 05:11 PM   #5
So it's running in heating mode past desired set point (stat temperature setting).
What Yuri said is where I'd begin as it would appear that the stat is bad.
Bryant 350MAV Furnace Code 31 Failure maq0 HVAC 0 10-10-2011 03:07 AM
Bryant Warranteed heat exchangers issues TruckTahoe HVAC 0 02-14-2011 03:21 PM
Bryant 350MAV fan won't turn on Doodle owner HVAC 1 09-15-2009 10:35 PM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 09:56 AM
Bryant Plus 90 start up problem mgraw HVAC 2 01-07-2008 06:54 PM
