Bryant 311AAZ036070 Limit Switch Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 02-24-2012, 12:42 PM   #1
I have a problem with my Bryant 80 plus furnace. The furnace would only turn on for a few minutes, then shut down and give me error code 33. This code list a number of things it could be so I eliminated most of them, including replacing the flame sensor and the blower. Immediately I tried the cheap replacement of the flame sensor, didn't work. Then I noticed blower would only work on low, so I left it running on low for some heat, but then it totally gave out, causing the upper limit switch to melt. So when I replaced the blower, I jumped the upper limit to see if it would work, and it does. But when I replaced the upper limit switch, it cuts the furnace off just like it did before.
Any suggestions from here?
coleary61385 is offline   Reply With Quote
Old 02-24-2012, 12:49 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,316
upper limit, the one above the burners with a small diode attached to it on some models? is that what you changed? check across the diode AND limit switch with an ohm meter and see if one of them is faulty.
Old 02-24-2012, 12:56 PM   #3
Yes, I replaced the limit switch above the burners..with a brand new part. Are you thinking that the new switch could be faulty?
Old 02-24-2012, 04:13 PM   #4
how
Rewards Points: 1,104
It sounds like both limit switches were doing their job of shutting down the furnace after a few minutes of run time.
Dirty air filters? dirty a/c coil? covered return air grill? Too many heat registers shut off? etc...
Have you considered doing a temp rise on the furnace and comparing that with the temp rise on the furnace rating plate to see if the furnace is really overheating??
how is offline   Reply With Quote
Old 02-24-2012, 04:16 PM   #5
Hvac Pro
yuri's Avatar
Yep......
Old 02-24-2012, 05:01 PM   #6
Check the new blower motor to make sure it's rotating the correct direction. If that's good increase to a higher speed. Safe to assume you replaced the capacitor along with the motor?
The Following User Says Thank You to Marty S. For This Useful Post:
how (02-24-2012)
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Problem replacing bathroom lightswitch rockchalk Electrical 7 12-19-2011 06:57 AM
Furnace limit switch Deereman HVAC 1 12-11-2010 10:56 AM
Problem w/ two 240v baseboard circuits on single double-pole switch. Skypalace Electrical 18 03-21-2010 04:16 PM
Another 3-way switch problem. speedster1 Electrical 6 01-16-2010 07:01 AM
