Bryant 1987 Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-31-2011, 01:46 PM   #1
The furnace runs continusly and Pilot lights but burners only lit once in a while. I smacked the warp switch with a wrench and the burners light every time now, (assume it is dirt in switch), but fan still runs on and on. Is this a fan limiter switch problem or maybe a bad thermostat?
bobhawg is offline   Reply With Quote
Old 01-31-2011, 05:45 PM   #2
HVAC / Plumbing
I believe that furnace blower is on a time delay. Comes on a few min. after the t. stat calls for heat & until t.stat reaches set temp. It will stay on if the burners don't lite
kenmac is offline   Reply With Quote
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 01:24 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 08:56 AM
Bryant +80 Gas Furnace won't light tr0910 HVAC 4 01-14-2009 07:11 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
