Brown "goop" - From Water Heater? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 02:10 PM   #1
Rewards Points: 83
Brown "goop" - from water heater?
Hi,
Our water heater, like the whole house, is less than one year old. This morning I was touching up some paint in the laundry room when I noticed some brown goop on the wall behind the water heater. It felt a little greasy and left a little bit of a greasy or oily mark on the wall. I looked at the copper (?) pipe at the top of the water heater and saw two "drips" suspended from the pipe. It's very possible I just haven't noticed the drops of bown stuff on the wall before, considering its behind the tank. But, I wonder what could make these little brown goopy spots over such a wide area behind the tank.
I've attached three photos: the tank from afar, the piping with the drips hanging off it, and the splatters on the wall.
Thank you!
Brown "goop" - from water heater?-dsc_0068_small.jpg   Brown "goop" - from water heater?-dsc_0069_small.jpg   Brown "goop" - from water heater?-dsc_0070_small.jpg
darthsmozers is offline   Reply With Quote
Old 02-26-2012, 02:16 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,092
Soldering paste/flux that is used to clean the joint and allow the solder to flow and a sloppy plumber with a turbotorch. You can wipe it off the joints and should or it will attack the metal and turn green in a few yrs. Use warm water to rinse them and wash your hands later as it is slightly corrosive or wear rubber gloves. The wall nothing can be done about except sand them off and repaint.
Old 02-26-2012, 02:29 PM   #3
Rewards Points: 83
Hmm, so you think the splatter is a leftover from 7 months ago instead of something new?
Old 02-26-2012, 02:32 PM   #4
how
Rewards Points: 1,070
I don't have any call to do electric tanks but...
Is it code to just strap lumex cable to water pipes and
who projects expansion tanks horizontally without support?
And with a spray pattern that wide on the wall makes me wonder about a vaccum breaker out of sight behind behind the exp tank.
how is online now   Reply With Quote
The Following 2 Users Say Thank You to how For This Useful Post:
ben's plumbing (02-26-2012), plummen (03-03-2012)
Old 02-26-2012, 02:33 PM   #5
Rewards Points: 12,790
That looks like old flux to me to, just wipe it off and move one. It most like been there since it was soldered.
Old 02-26-2012, 02:40 PM   #6
Rewards Points: 83
I guess if I clean it then discover more later we'll know for sure. Thanks!
Old 02-26-2012, 05:10 PM   #7
Rewards Points: 616
how does bring in a good point your expansion tank is horizontal and not supported so when bladder fails and fills with water that is some extra weight being put on fitting he asked is it code i find if you ask an inspector on that he will reply most be installed to manufactures directions and here are watts and flexcon
http://media2.wattswater.com/1915323.pdf
http://www.flexconind.com/pdf/wh-whv_install.pdf
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 02-27-2012, 04:46 AM   #8
Rewards Points: 1,192
Real Butch! What's in the walls?
bobelectric is offline   Reply With Quote
Old 02-27-2012, 05:39 AM   #9
the Musigician
DangerMouse's Avatar
I'm PRETTY sure this install was not permitted nor inspected properly.
NWIH would MY inspector let that "floating tank" stay, for one thing.
DM
The Following 2 Users Say Thank You to DangerMouse For This Useful Post:
hvactech126 (03-03-2012), plummen (03-03-2012)
Old 03-03-2012, 10:51 AM   #10
Rewards Points: 83
Hmm. I will try to photograph behind the tank to see if there is any hidden extra support.
Old 03-03-2012, 12:50 PM   #11
Rewards Points: 77
Hmmm, regarding the "floating" tank issue, that is a good point but is also common practice unfortunately And does not seem to be caught often by inspectors. I have lived in 3 homes, one in nj, and two in Pa and all have had the expansion tank mounted sideways. township inspectors and home inspectors haven't mentioned anything in either case. I'll have to add that to the "to be checked out" list...
dengle is offline   Reply With Quote
Old 03-03-2012, 01:16 PM   #12
how
Last week I visited a broken boiler where the horizontal water logged extrol expansion tank had bent the fittings on its way through the zone valve wiring. When those things get completely water filled, they weigh as much as a stone of that size would.
Every manufacture's instructions that I've ever read never allows an unsupported
horizontal installation.
DangerMouse (03-03-2012), plummen (03-03-2012)
Old 03-03-2012, 09:55 PM   #13
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
No,Id atleast sleeve that romex in greenfield between the heater and junction box myself.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
