Broken Humidifier Water Line - HVAC - DIY Chatroom Home Improvement Forum
Old 02-19-2014, 06:33 PM   #1
Handyman
brucem609's Avatar
Rewards Points: 79
Broken humidifier water line
Ok, so this is the second time my humidifier water line broke. This is the line coming off of the copper pipe. It's tapped in with a saddle valve and then the cheap tubing leads to the water inlet on the humidifier.
Question: is there a braided or more substantial type of tubing I can get/use to replace the cheap standard stuff plastic tubing?
This sucks cleaning up behind the water heater, under the washer etc.
Thanks guys
Sent from my iPhone
brucem609 is offline   Reply With Quote
Old 02-19-2014, 06:35 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,158
yeah, 1/4" copper tubing. HDepot may have it.
The Following 2 Users Say Thank You to yuri For This Useful Post:
ben's plumbing (02-22-2014), hvactech126 (02-23-2014)
Old 02-19-2014, 06:37 PM   #3
Rewards Points: 12,882
#1 In most places saddle valves do not even meet code. They plug up and leak.
Replace with a real 1/4 turn valve with a 3/8 compression fitting.
And yes a braded pipe would be much better.
gregzoll (02-22-2014)
Old 02-19-2014, 06:46 PM   #4
Handyman
brucem609's Avatar
Rewards Points: 79
1/4 copper? Is that flexible?
A 1/4 turn valve- does that involve soldering?
What's the easiest? For now
Sent from my iPhone
Old 02-19-2014, 08:12 PM   #5
Hvac Pro
yuri's Avatar
Saddle valves are OK just a pain if they leak around the stem. They use flexible copper for hooking up dishwashers and HDepot may have it or any plumbing supply store.
Old 02-19-2014, 08:35 PM   #6
Rewards Points: 484
Copper line is the only way to go. I dont like plastic tubing, whether it be used on humidifiers, or ice makers, or whatever else.
If you live in a region that uses evaporative cooling, you can get a 50 foot roll of 1/4" copper in the cooler section at any big box store and it's usually cheaper than buying it in the plumbing section.
sammy37 is offline   Reply With Quote
Old 02-21-2014, 10:43 PM   #7
Handyman
brucem609's Avatar
Rewards Points: 79
I ended up going with 2-12" braided tubing with a brass connector-I needed 2' and the only other one available was 4' long. But it doesn't sound like it is coming on? I remember before,that it sounded like the humidifier would come on with the heater, but now I hear nothing?
What do you all think?
Sent from my iPad using DIY Forum
Old 02-21-2014, 11:08 PM   #8
Rewards Points: 6
Turn your humidistat to max high and then turn up the thermostat. When the furnace turns on you should hear the solenoid click. Hopefully the water runs. If it does, the humidistat was just satisfied and it didn't need to run.
Dan
djlandkpl is offline   Reply With Quote
Old 02-22-2014, 07:20 AM   #9
Rewards Points: 1,214
Attachment 81636
Attachment 81637
Attachment 81638
" Looks Good" Now get rid of that saddle valve when you get some free time. No hurry.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
Old 02-22-2014, 07:22 AM   #10
I would have used 1/4" copper with a new valve but there's more ways than one to accomplish what you want.
The Following 2 Users Say Thank You to COLDIRON For This Useful Post:
gregzoll (02-22-2014), hvactech126 (02-23-2014)
Old 02-22-2014, 06:16 PM   #11
Rewards Points: 6,652
Yep. A Sharkbite T fitting, and a 1/4 Turn Ball valve for the Humidifier, along with the Copper or PVC Flex line, would work better, then the Saddle Valve.
The Following User Says Thank You to gregzoll For This Useful Post:
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 07:03 PM
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 10:08 AM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 06:07 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 10:26 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
