Broke Furnace? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-17-2013, 09:02 PM   #1
Broke furnace?
Hi there,
I have a 1 year old Goodman furnace which I think something may be wrong with. When the AC/heat is turned off through the thermostat, I hear a clicking sound one or two times an hour. Seems like it's coming from the furnace. The furnace itself works fine when turned on (cools and heats the house) It doesn't sound like a pilot trying to light.
Do furnaces normally make clicking sounds even when switched off? Is it the thermostat trying to communicate with the furnace?
If I get a professional to come and take a look at it where should I direct him to look?
Deepi is offline   Reply With Quote
Old 10-17-2013, 09:50 PM   #2
Rewards Points: 150
Could be from metal expanding and contracting in the furnace
romex1220 is offline   Reply With Quote
Old 10-17-2013, 10:00 PM   #3
Thanks, is there anything I can do to make the clicking stop?
I wonder why metal would expand/contract even though the heat or AC wasn't running for months.
Just turned on the heat today and going to monitor whether I hear the clicks.
Old 10-17-2013, 10:00 PM   #4
Rewards Points: 77
It is probably one of the relays on the control board you hear clicking. For example, every time the blower turns on or off the blower relay is activated and clicks. The blower is set up to run for 30, 60, 90, or 120 seconds after the furnace or a/c shuts off. Does the click you hear sound like the one the thermostat makes when it turns on or off?
firedawgsatx is offline   Reply With Quote
Old 10-17-2013, 10:16 PM   #5
It's possible that's the case when the thermostat is switched to "on", however I've been hearing the clicks/ticking for months now even though the thermostat has been set to "off."
It's a fairly loud distinctive click if you're in the basement and sounds like a small metal object tapping on the furnace. Last year there was some condensation dripping into the furnace and caused it to malfunction. We had to get a new furnace. I'm worried that perhaps the same thing is happening and causing some type of electrical issues and that's causing the clicking I'm hearing. Is there a possibility of fire?
I would think that there should be no noise coming from a furnace that isn't being used, but I could be wrong.
Old 10-18-2013, 05:30 AM   #6
An old Tradesmen
Rewards Points: 6,060
If you had a contractor sell and install this furnace last year. Then it should still be under the 1 year labor warranty from that contract. call them back out to check it. Don't wait till the warranty expires.
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
