Bridging - HVAC - DIY Chatroom Home Improvement Forum
Old 06-06-2015, 02:22 PM   #1
Bridging
I just changed my fan motor. How can I jump the new fan capacitor to the existing capacitor?
Dustin84 is offline   Reply With Quote
Old 06-06-2015, 04:05 PM   #2
Rewards Points: 907
Is the new motor a 3 wire or 4 wire?
Bitters is offline   Reply With Quote
Old 06-06-2015, 06:00 PM   #3
Rewards Points: 1,989
You have me totally confused ! :-(
Are you trying to use 2 capacitors on a fan motor ?
I guess I am slower than usual , today ? Maybe I need drawings or pictures ? ( A bowl of ice cream might help ? :-) )
God bless
Wyr
WyrTwister is offline   Reply With Quote
Old 06-06-2015, 07:43 PM   #4
Rewards Points: 46
God bless
Wyr
I think I'm in the same boat. To much sun maybe.
Cheers!
supers05 is offline   Reply With Quote
Old 06-06-2015, 07:56 PM   #5
An old Tradesmen
Rewards Points: 8,184
If your doing a 4 wire set up, no need to jumper from one cap to the other.
If your doing a 3 wire set up, and the new motor is a different uF then the old one. The jumper goes from the C of the old cap to any one of the terminals of the new 2 post cap.
Metal or wood cross bridging Mijotter Building & Construction 16 01-11-2013 01:49 AM
Mid span bridging lylsutherland Building & Construction 2 10-29-2012 11:10 PM
Bridging or not? edselsouth1 Building & Construction 27 05-06-2012 10:19 AM
Effect of bridging 2"x10", 14' span joists BMS98 Building & Construction 8 03-11-2011 06:50 AM
Bridging between joists cortell Building & Construction 0 01-03-2011 08:11 AM
