Breaker Tripped Again - HVAC - DIY Chatroom Home Improvement Forum
Old 11-29-2006, 06:31 AM   #1
Breaker tripped again
Yikes, now I'm really confused.Replaced the Capacitor for the blower motor and furnace ran fine all day yesterday thru many cycles.This morning comming out of setback at 7am I heard the furnace click on then stop. Yep breaker tripped agian.Reset breaker now its working fine again,can't get it to trip now. So I'm assuming if it sits idle for 8hrs like last night(set point was at 19C and temp never got below 20C)and the motor has cooled down thats when it draws to much current to get going.Could it be anything else?
rookie50 is offline   Reply With Quote
Old 11-29-2006, 08:11 AM   #2
Does this breaker supply power to any other circuits?
redline is offline   Reply With Quote
Old 11-29-2006, 08:39 AM   #3
Thoroughbred Mopar Man
Rewards Points: 502
Hi rookie50
Most breakers are made to cycle only about twelve times before the tension bar is shot. I would say if the motor amperage is not shooting off the scale, the breaker itself is shot from tripping all these times.
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 11-29-2006, 09:10 AM   #4
Originally Posted by #CARRIERMAN View Post
Hi rookie50
Rusty
square D breaker never had any problems with them. Anyway first one tripped twice so I replaced it. This replacement has now tripped twice.
I doubt the breaker is the problem. A 16 year old motor, well maybe its time has come and gone, this could be early sign of failure.It seems to be happening after a long period where the motor hasn't run.
Old 11-29-2006, 09:30 AM   #5
Rewards Points: 502
Hi rookie50
I am betting you are probably right, if you got 16 years out of a motor. Give it a gracefull burial.
Rusty
Old 11-29-2006, 09:58 AM   #6
Hi rookie50
Rusty
Yes I will put it in the nice new motor box container before tossing.Hehe. Thanks Rusty
Old 11-29-2006, 01:05 PM   #7
Hi rookie50
Rusty
Rusty I decided to give motor one more day of life.All my metering says its fine, pulls about 12A for a sec or two then runs about 7A.Even the voltage drop when it kicks in is well within acceptable limits.
So I bought a brand new breaker and will let it go another day. If it again trips then I'll put the new motor in.If it still trips after that then I'll probably go bald. Will let you know the outcome. Thanks.
Old 11-29-2006, 01:20 PM   #8
Rewards Points: 502
Hi rookie50
If you have to replace the motor, I would reccomend a A/O Smith model # DL1076. We have had excellent service out of these motors.
Good luck
Rusty
Old 12-02-2006, 05:57 PM   #9
Hi rookie50
Good luck
Rusty
Rusty, hard to believe but third time is a charm. It appears it was the breaker(s) after all. Held off replacing motor and bought a new 15Amp sq D breaker and its be fine now since Thursday.Supplier says he will accept motor return since I hadn't tried to install yet.
Anyway problem solved thanks for your patience and advice!!
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 02:29 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
Breaker Buzz SkipI Electrical 2 07-13-2007 07:48 PM
tripped breaker rookie50 HVAC 7 11-28-2006 02:40 PM
