-   -   Breaker tripped again (http://www.diychatroom.com/f17/breaker-tripped-again-5091/)
rookie50 11-29-2006 06:31 AM
Yikes, now I'm really confused.Replaced the Capacitor for the blower motor and furnace ran fine all day yesterday thru many cycles.This morning comming out of setback at 7am I heard the furnace click on then stop. Yep breaker tripped agian.Reset breaker now its working fine again,can't get it to trip now. So I'm assuming if it sits idle for 8hrs like last night(set point was at 19C and temp never got below 20C)and the motor has cooled down thats when it draws to much current to get going.Could it be anything else?
redline 11-29-2006 08:11 AM
Does this breaker supply power to any other circuits?
#CARRIERMAN 11-29-2006 08:39 AM
Hi rookie50
Most breakers are made to cycle only about twelve times before the tension bar is shot. I would say if the motor amperage is not shooting off the scale, the breaker itself is shot from tripping all these times.
Rusty
rookie50 11-29-2006 09:10 AM
Originally Posted by #CARRIERMAN (Post 25242)
Hi rookie50
Rusty
square D breaker never had any problems with them. Anyway first one tripped twice so I replaced it. This replacement has now tripped twice.
I doubt the breaker is the problem. A 16 year old motor, well maybe its time has come and gone, this could be early sign of failure.It seems to be happening after a long period where the motor hasn't run.
#CARRIERMAN 11-29-2006 09:30 AM
Hi rookie50
I am betting you are probably right, if you got 16 years out of a motor. Give it a gracefull burial.
Rusty
rookie50 11-29-2006 09:58 AM
Originally Posted by #CARRIERMAN (Post 25247)
Hi rookie50
Rusty
Yes I will put it in the nice new motor box container before tossing.Hehe. Thanks Rusty
rookie50 11-29-2006 01:05 PM
Hi rookie50
Rusty
Rusty I decided to give motor one more day of life.All my metering says its fine, pulls about 12A for a sec or two then runs about 7A.Even the voltage drop when it kicks in is well within acceptable limits.
So I bought a brand new breaker and will let it go another day. If it again trips then I'll put the new motor in.If it still trips after that then I'll probably go bald. Will let you know the outcome. Thanks.
#CARRIERMAN 11-29-2006 01:20 PM
Hi rookie50
If you have to replace the motor, I would reccomend a A/O Smith model # DL1076. We have had excellent service out of these motors.
Good luck
Rusty
rookie50 12-02-2006 05:57 PM
Originally Posted by #CARRIERMAN (Post 25268)
Hi rookie50
Good luck
Rusty
Rusty, hard to believe but third time is a charm. It appears it was the breaker(s) after all. Held off replacing motor and bought a new 15Amp sq D breaker and its be fine now since Thursday.Supplier says he will accept motor return since I hadn't tried to install yet.
Anyway problem solved thanks for your patience and advice!!
