Breaker Pops On Lennox HS24-651-1P - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-07-2011, 04:50 PM   #16
Rewards Points: 866
I may have the part numbers and some of the rating info. When I got the dual cap off there was no corrosion under that strap where is very legibly printed:
YORK
60/10MFD
74H1001 (there may be more under the corrosion which I will carefully clean off)
SFD44601. It looks much taller than the 53H2201.
As for the Start Capacitor, it is clearly marked. The MFG is AeroM, 189-227MFD, 330VAC. There are three numbers of which one has to be the part number. 72H7201, PSB8R33189R, and 677-9149-01.
Klawman is offline   Reply With Quote
Old 08-07-2011, 06:13 PM   #17
An old Tradesmen
Rewards Points: 7,814
The 677-9149-01 is the part number. but its an obsoleted number. Should be able to get them from most HVAC parts supply houses, if they will sell to you. Other wise you'll have to go to Grainger, or order them over the internet.
Old 08-07-2011, 06:42 PM   #18
Rewards Points: 866
Thanks. A buddy of mine clued me in on how it may be difficult to buy Lennox parts from a supply house. I may have located the 677-9149-01 on E-bay. One from CozyParts. com is
CAPACITOR-START 189-277 MFD 330 VAC, 72H7201
$86.43 . That seems ridiculously high given what seems to be equivalent parts on E-bay run betweem $7 and $23. As long as it physically fits, is rated 189-277 MFD 330 VAC, can I by one of these off of E-bay or at any supply house. A large one in Santa Fe Springs has one for $12 and I can find a reason to get out that way.
I also located a dual capacitor replacement on CozyParts for $30 which I can live with. It isn't listed in this Santa Fe Springs outfit's online catalog but I will call to see if they have one. It probably is local to So Cal but it's called McMasters-Karr.
I don't want to get too much into this because I guess the compressor may still be bad.
Old 08-07-2011, 07:03 PM   #19
An old Tradesmen
As long as it has the same ratings, you can use one from ebay, or some other store.
The Following User Says Thank You to beenthere For This Useful Post:
Klawman (08-07-2011)
Old 08-07-2011, 07:05 PM   #20
Rewards Points: 866
And the only ratings that I need be concerned with are the VAC and MFD or do I care about megahertz, which often isn't even provided? TIA
The dual capacitor replacement is 440VAC. If I get one, does the start capacitor then also have to be uprgraded to 440 or can it still be 330VAC?
Old 08-08-2011, 04:05 AM   #21
An old Tradesmen
The start can remain 330 volt. The capacitor VAC rating is only for its internal electrical insulation.
Old 08-08-2011, 01:01 PM   #22
Rewards Points: 866
Cool.
I remetered after replacing all disconnects. On the new meter the ohms fluctuate (for instance what measures 1.0 goes to 1.1 and back and occasionally reads 0.9 or 1.2) I also retook the ohms with the old digital adjusted for resistance across the prongs. I got a 2.3., 1.2 (sometimes reading 1.1), and a 1.1. I now realize that the sum of the start and run winding should equal the third. It appears they do that if I disregard the fluctuations on the one that produces extremes of .9 and 1.2)
Reading further, I understand that the start winding should be have much higher resistance than the run winding. As measured, they are nearly equal.
I also realized that my new meter has an infinity reading (as I think the old one does) All 3 wires measured 1.L (infinity) to ground. I believe that does not mean there is no short as the meter may not be senitive enough to detect a short.
Does the fact that run and start windings have nearly equal resistance indicate anything. I do note that the start and run windings of the fan have more measurable difference (27.8 to 21.4). The the fan works with the compressor windings disconnected.
Old 08-08-2011, 06:16 PM   #23
An old Tradesmen
Start to common and run to common reading the same often means they are shorted to each other.
Klawman (08-08-2011)
Old 08-08-2011, 07:50 PM   #24
Rewards Points: 866
I was wondering if equal resistance meant that. I took the little Commercial Electric pocket meter and got a larger Klein. It is so much easier to read, but I am still getting the same data.
Would a short from the start winding to the run winding be compatible with an infinite ohm measurement? I would think it would.
Old 08-08-2011, 08:27 PM   #25
Common to start+ common to run = run to start
Master of Cold is offline   Reply With Quote
Old 08-08-2011, 10:50 PM   #26
Rewards Points: 866
That is cause whenn you measure resistance from s to r you are actually measuring the combined resistance of the start and run windings that are connected in series at the common terminal.
I think it is time to get some quotes on a new compressor unit. Hopefully I can get something to basically drop on the existing pad and hook up with the existing system without much additional expense. I even placed a call to guy recommended by someone who is with a local HVAC service business.
Old 08-09-2011, 02:01 AM   #27
Rewards Points: 866
I retested the capacitors with the Klein meter and this time the start capacitor checked out with 213.8 MFD. It is rated 189 to 227 MFD. Still, the common to hermes side of the dual run capacitor only measures a couple of nF (rated 60 MFD) while the run side is 10.49 MFD (Rated 10 MFD).
beenthere is likely prescient about a short between the start and run windings. but I ordered a dual capacitor. It is probably a wasted $40 but will give it a try.
Old 08-09-2011, 02:13 AM   #28
JJboy's Avatar
Replace the dual capacitor.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 08-09-2011, 02:55 AM   #29
Rewards Points: 866
I ordered the part an hour ago,. Somehow a duplicate order went through. I emailed the vendor not to ship the dupe and paypal not to pay the second order. Some things just are a PITA.
Old 08-14-2011, 05:23 PM   #30
Rewards Points: 866
I replaced the dual run capacitor that had a dead hermes side. It made no diference.
I also bought a better multi meter, a Klein MM1000, and reread the condensor windings; not just at the disconnected wires in the control box but I took my readings off of the terminals on the condensor.
C to S: 2.7 to 2.8 Ω
C to R: 3.1 Ω
S to R: 4.4 to 4.5 Ω
I also rechecked resistance from terminals to the condensor crank case, which was done after I scraped the paint off a spot. The same readings were obtained when resistance was read to the copper suction pipe instead of the crank case.
The readings were greatly differen
t if I probed the terminal with red and the crank case with black or if I swithed them.
Black probe to copoper and Red to any condensor terminal: about 4.65 MΩ creeping up to over 5 MΩ.
Red probe to copper and black to any condensor terminal: 14 MΩ creeping up to over 15 MΩ.
Whe I say it was creeping resistance was climbing at a rate of about .01 MΩ per second and I didn't wait to see how high it would eventually climb.
Is it at all likely that the problem is a bad contactor. It pulls in when the thermostat is switched on at which time a large spark is seen between the points connecting the load and line side of L1. Aat the very instant the circuit breaker pops. The wires connecting the common and the run terminals of the condensor to the two load sides of the contactor were pretty badly fried at that point. The insulation on one was melted right at the disconnects and the disconnect on one side had gotten so hot that a piece was welded to the male side projecting from the contactor.
Does it now sound as though the compressor itself may not be the problem, but it may be a short in the contactor or does the new data regarding condensor indicate a bad winding/short in the condensor.
Is there any way of testing the contactor? I am thinking of removing it so I can see better what is going on. Perhaps it has a direct short somewhere I can't see with it mounted.
Is it possible that this could be caused by some badly burnt contacts? I am bnot certain, but it only seems to be popping the 50 A circuit breaker when both the lead from the load side of line 2 is connected to the run terminal of the compressor AND the lead from the load load side of line 1 is connected to the common terminal of the compressor.
I am guessing that means either the start winding nor the run winding is pulling enough amps to pop the 50 A CB by themselves, but together it pops immediatley.
If the contacts are badly burn would that cause a sudden surge that would immediately pop the breaker? It almost seems that its popping before either capacitor can charge.
TIA
Lennox Whisper Heat G20 series occasionally pops when igniting CubsWin HVAC 16 01-31-2011 08:59 PM
Bad breaker panel??? drjay9051 Electrical 9 08-25-2010 03:43 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
