Old 03-05-2011, 04:48 PM   #1
JJboy's Avatar
Brazing Technique
Using 15% silver brazing rod. Do I still need to use flux and clean the copper surface with sand cloth ?
For my understand I need use flux and sand cloth with soldering not brazing.
I'm asking this because I'm seeing both ways in the Youtube.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 03-05-2011, 06:04 PM   #2
MXer
3 legged dog's Avatar
Brazing Technique
I use flux, or sand if the pipe is visibly dirty or oily.
3 legged dog is offline   Reply With Quote
Old 03-05-2011, 06:04 PM   #3
Brazing Technique
for stay silv 15, no flux is required for copper to copper brazing. i think that anything at about 15% silver or under, no flux is required. the higher silver, lower temperature rods require a white brazing flux.
NitroNate is offline   Reply With Quote
Old 03-05-2011, 06:50 PM   #4
Brazing Technique
No flux is needed. You don't have to clean the pipe but unless it's real dirty. Don't forget to purge with nitrogen.
Hubcap626 is offline   Reply With Quote
The Following User Says Thank You to Hubcap626 For This Useful Post:
JJboy (03-05-2011)
Old 03-06-2011, 03:37 AM   #5
HVAC Supermodel
unicursalhex's Avatar
Brazing Technique
Haha guys actually use sand cloth and flux with oxy-ace
Mark it zero!
unicursalhex is offline   Reply With Quote
Old 03-06-2011, 08:59 AM   #6
Master General ReEngineer
Bondo's Avatar
Brazing Technique
Ayuh,... If you sand, 'n flux,...
You'll be making fewer repairs later....
Old 03-06-2011, 09:26 AM   #7
Brazing Technique
No need for flux when using sil/phos rods, the phos is the flux. Joints still need to be clean.
Old 03-06-2011, 05:05 PM   #8
HVAC Supermodel
Brazing Technique
If you use the high silver content stuff you can braise a joint in the mud
Mark it zero!
Old 03-06-2011, 05:26 PM   #9
JJboy's Avatar
Brazing Technique
Old 03-07-2011, 07:15 PM   #10
hvaclover's Avatar
Brazing Technique
15% silver phos is used because it make a strong joint. But you still have to sand the copper.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 03-07-2011, 07:20 PM   #11
hvaclover's Avatar
Brazing Technique
You guys!!!
There is phophurous is the braze rod. That will burn thru metal. Adding flux just adds mor contaiminants to the system.
If you are going from copper to steel you should use 45% silver, but 15% and stay silv flux will do it up.
Left a kleenex in suction line while brazing tesla500 HVAC 0 07-13-2010 11:19 PM
Faux Finish technique BarcelonaGuy Painting 0 07-03-2010 07:59 PM
How to remove a technique I did to my kithen walls ekolp Painting 5 12-31-2008 05:55 PM
This brazing rod good? integlikewhoa HVAC 10 12-27-2008 08:00 PM
Texture technique Txmomof2 Painting 4 02-10-2008 09:14 PM
