-   -   Brazing Technique (http://www.diychatroom.com/f17/brazing-technique-97339/)
JJboy 03-05-2011 03:48 PM
Brazing Technique
Using 15% silver brazing rod. Do I still need to use flux and clean the copper surface with sand cloth ?
For my understand I need use flux and sand cloth with soldering not brazing.
I'm asking this because I'm seeing both ways in the Youtube.:thumbsup:
3 legged dog 03-05-2011 05:04 PM
I use flux, or sand if the pipe is visibly dirty or oily.
http://www.fresnooxygen.com/pictures...S435-00450.jpg
NitroNate 03-05-2011 05:04 PM
for stay silv 15, no flux is required for copper to copper brazing. i think that anything at about 15% silver or under, no flux is required. the higher silver, lower temperature rods require a white brazing flux.
Hubcap626 03-05-2011 05:50 PM
No flux is needed. You don't have to clean the pipe but unless it's real dirty. Don't forget to purge with nitrogen.
unicursalhex 03-06-2011 02:37 AM
Haha guys actually use sand cloth and flux with oxy-ace
Bondo 03-06-2011 07:59 AM
Ayuh,... If you sand, 'n flux,...
You'll be making fewer repairs later....
Marty S. 03-06-2011 08:26 AM
No need for flux when using sil/phos rods, the phos is the flux. Joints still need to be clean.
unicursalhex 03-06-2011 04:05 PM
If you use the high silver content stuff you can braise a joint in the mud
JJboy 03-06-2011 04:26 PM
:thumbup:
hvaclover 03-07-2011 06:15 PM
15% silver phos is used because it make a strong joint. But you still have to sand the copper.
hvaclover 03-07-2011 06:20 PM
You guys!!!
There is phophurous is the braze rod. That will burn thru metal. Adding flux just adds mor contaiminants to the system.
If you are going from copper to steel you should use 45% silver, but 15% and stay silv flux will do it up.
