This Brazing Rod Good? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-27-2008, 01:53 AM   #1
This brazing rod good?
I have 3 sticks of this brazing rod Im wondering if its ok to use on a Trane 3 ton 2 stage 410-A unit.
Its made by Bernzomatic part# PC-3
Its a copper phosphorus brazing and welding rod.
Says: tensile strenght 40,000 psi
working temp 1310 to 1475 degress
joins copper to copper without flux or copper to copper alloys(brass and bronze). This alloy is widely used in refrigeration, electrical and plumbing to join copper tubing and pipe, electrical wires and flexible tubeing. Excellent for soldering copper tubing connections even with water in the line.
The thing that gets me is it doesnt say anything about the the silver content. I have heard some people say that you have to use 5% or higher. My instruction manual doesnt say what % to use.
It only says " use a dry nitrogen purge and braxing alloy without flux when brazing the field line to the copper factory connection." Also says to "flow dry notrogen threw one port out the other and only to use accepted good brazing techniques"
What do you think?
integlikewhoa is offline   Reply With Quote
Old 12-27-2008, 06:42 AM   #2
An old Tradesmen
Rewards Points: 7,808
Doesn't have to have Silver in it.
Ok to use, won't flow as easy as a Silver content brazing rod.
Nitrogen prevents internal oxidation while brazing.
Old 12-27-2008, 09:32 AM   #3
Not ok to use from what I have seen. Does not hold up over time and they are prone to vibration cracks more so than a silver baring braze. Been back on enough of them to form an informed opinion.
I use nothing less than 15% silver rods
hvaclover is offline   Reply With Quote
Old 12-27-2008, 10:29 AM   #4
Hmmm so tis is the question....... To silver or not silver.
Old 12-27-2008, 10:40 AM   #5
An old Tradesmen
I use mainly 15%.
I've used 5%, it doesn't flow as good as 15.
And 45% is too expensive for copper to copper brazing.
Old 12-27-2008, 10:57 AM   #6
Originally Posted by beenthere View Post
I use mainly 15%.
45% has it's place in steel to copper application.
The place it's used most in hvac is domestic refrigerators for sealed system, work-comppressor replacement ect.-
Old 12-27-2008, 12:12 PM   #7
Idiot Emeritus
Rewards Points: 1,492
I wouldn't put a huge amount of faith in the instructions.
It says "Excellent for soldering copper tubing connections even with water in the line."
With a working temperature of over 1000 degrees, I'd like to know just exactly how you're going to get a copper tube full of water hot enough to melt the solder!
Just a thought.
Rob
micromind is offline   Reply With Quote
Old 12-27-2008, 01:05 PM   #8
So with more silver in it, its going to easier to use? Because it will flow into the joints eaiser? How much should I be paying for a stick of this. I think the stuff I had I only paid 3.00 for like 3 sticks. Probley goes to show it dont have silver in it.
Old 12-27-2008, 04:21 PM   #9
An old Tradesmen
I don't know what it will cost you for just 2 or 3 sticks, I buy it by the tube, at 28 sticks to the tube.
But, it cost a lot more then a buck per stick.
Old 12-27-2008, 06:15 PM   #10
I figured I have the cheap sticks.
Ill have to barrow some from somewhere if I cant find just a stick somewhere. I'm only doing my own house and like 4 connections at that, so I dont need a whole bunch fo them. Thanks
Old 12-27-2008, 07:00 PM   #11
Optimist Bwahahahahahahahaha!
Can't find good laminate comparison anywhere cpsilo1 Flooring 3 03-20-2011 04:49 PM
How can I tell if my taping is good enough? yummy mummy Building & Construction 4 10-01-2008 09:16 AM
Good equipment to use for carpet cleaning? Beth777 General DIY Discussions 5 08-29-2008 08:16 PM
What would be good quality paint kenny357 Painting 13 06-07-2007 01:36 AM
