Brayant Condensing Unit Noise - HVAC - DIY Chatroom Home Improvement Forum
Old 05-29-2013, 10:59 PM   #1
MikeKy55's Avatar
Rewards Points: 254
Brayant condensing unit noise
I have a Bryant A/C and furnace in my home that is about 10 years old. The unit runs fine and if you want, it will chill the house well enough to hang meat on 85 days. But the condensing unit outside makes a pulsating sound. I can't hear it inside the house, but if I'm on the deck I hear it real well. Just glad I don't live next door to me . What would cause this? Should I put some kind of rubber pads under the feet?
Tried to edit the spelling in the thread name, but don't have admin. clearance.
'It's never too late to say ''THANK YOU'' to a veteran of our armed services'
MikeKy55 is offline   Reply With Quote
Old 05-29-2013, 11:11 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,422
we cannot hear it from here. rubber pads under it may help. compressors can pulsate and there is not much you can do about it. usually the rubber pads do the trick. condenser fan blade may be off balance too.
The Following User Says Thank You to yuri For This Useful Post:
MikeKy55 (05-29-2013)
Direction/spacing of 2-1/2 ton Carrier 38HDR030 condensing unit ? ric in alberta HVAC 1 06-20-2012 06:56 AM
trane condensing unit destrier HVAC 1 07-08-2011 03:41 PM
Trane condensing unit keeps running fastback4 HVAC 1 06-08-2010 07:49 PM
Outside Condensing Unit not working Will B HVAC 3 05-07-2010 07:11 AM
AC condensing unit failure? Hotinsummer HVAC 3 08-09-2009 03:08 PM
