Brand New Noisy Metal Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 11-13-2008, 04:02 AM   #1
Brand new noisy metal duct
I need to know if there's a way before they sheetrock to somehow prevent the creaking and cracking of the duct every time the furnace turns off. I think it's from the heating and cooling of the metal and it's shrinking and that's making it "pop". I know it might sound like something small but since the ceiling is wide open, hey, why not?
klein is offline   Reply With Quote
Old 11-13-2008, 04:23 AM   #2
Journeyman
Did you cross-brake the metal? What guage metal did you use? What size is the trunk?
pipefitter636 is offline   Reply With Quote
Old 11-13-2008, 05:26 AM   #3
An old Tradesmen
Rewards Points: 6,928
As above, is it cross braked.
Also, is the supply too tight to the joist.
Is it sized right. Undersized sheet metal pops if undersized too much.
Old 11-13-2008, 11:04 AM   #4
what they said
kennzz05 is offline   Reply With Quote
Old 11-14-2008, 05:29 AM   #5
I didn't install it. An HVAC shop did and it's getting inspected so I'm hoping everything is sized right. As far as the installation goes, the duct is smooth (as in there is no x's scratched into it) but it seems too thick of steel to do that in. It's hung off little L brackets and the sections are folded together. Where it transitions to round 6" duct, those are supported with bars that are wedged between the floor joists. It's not installed tight to the floor joists as in there is a an inch or so gap on the top. It only makes sounds when it's cooling down versus heating up, I believe.
isolating noise transmission in metal duct work BrandonHook HVAC 2 12-07-2008 06:37 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
Tapping into existing metal duct Mike_Atlanta HVAC 1 11-30-2007 12:07 AM
Connect metal duct to flex? tigerbalm2424 HVAC 3 03-12-2007 02:30 PM
