Old 07-03-2009, 11:29 PM   #1
Brand new Carrier Infinity 16 Heat Pump Stopped Working I think
Hello,
We had a new heat pump and furnace installed 2 months ago. Today (in the middle of a mini heat wave) the heat pump appears to have stopped working. The temperature inside had been steadily climbing to 80 degrees.
On the Carrier Infinity Control unit, we have "Cool" turned on and the Fan on High, but the status shows the following -
Mode: Cool
AC: Off
Fan: On
The LED light on the Control unit indicates that the system is cooling and the furnace is blowing air through, however the fan on the heat pump is not on and the air coming through is not cool.
THe circuit breaker switch is on and the heat pump outdoor disconnect switch is on. We've tried turning both off for 30 seconds, then on again.
We've called Carrier and the company we went through, Carrier is off for the holiday and the company we purchased through put us 'on the list' for a technician.
(UPDATE since I've started typing this!)
Actually, after leaving it off for a while, it is now working again and the AC status says "High Stage". Is it possible that it overheated? The outside temp has been over 90 the past couple days and is now in the low 80s. I'm concerned about the possibility of it overheating when we really need it!
Thanks for any information or advice!
needmyac is offline   Reply With Quote
Old 07-04-2009, 08:18 AM   #2
An old Tradesmen
The controller will have the error codes stored for the tech to see what it locked ouot on.
It shouldn't "overheat" just because its in the 90s.
Old 07-07-2009, 07:10 PM   #3
Thanks for the reply, beenthere. The tech came out yesterday and did see some error code that implied it shut itself off because it was overcharged...
He said something (I can't remember what) had been super charged, so when it got really hot out and we were using it more, it overcharged and a fail safe thing made it shut itself off. When they were fixing it, they couldn't test it very easily because it wasn't hot again, so we're supposed to wait till another hot day and see how it works. If it shuts itself off again, call them right away. :/ Here's hoping...
Old 07-07-2009, 07:12 PM   #4
An old Tradesmen
They shuld have had no problem correcting the charge.
If they know how to charge a system properly.
More On This Topic
Hi! This is Jon on behalf of Expert Village. In this video clip, I will be answering the question how does the cooling system work. The primary job of the cooling system is to keep the engine from overheating as you are driving. As liquid passes through... Read More »
More Ways to Glaze Pottery
More Ways to Glaze Pottery by Expert Village
Hi, I'm Nipa Banerjee from Arts Space India I'm talking on behalf of Expert Village. Now our firing is completed, after 1100 degree Cecilius temperature we keep the furnace 1 day for cooling. Now I'm opening the furnace see this is the door and our cups... Read More »
I am Chitrotpola Mukherjee speaking on behalf of Expert Village and I am from Oxpace, India. Today I am going to show you how a ceramic, that is a glazed piece of art, is made. First for glazing we have to get the piece that we wish to glaze; we wish to... Read More »
You can tell the difference between heat stroke and heat exhaustion by the overall condition of the victim. Although similar, the two need to be approached with different levels of urgency. While heat exhaustion is a overheating of the body, heat stroke... Read More »
From the water pump to the head gasket and radiator, the cooling system of the car is the heart of the engine. It should be inspected and maintained on a regular basis. By keeping all components of the cooling system running optimally, you can extend the... Read More »
Replacing Heat Pump system - Carrier or Rheem? CoolMan74 HVAC 6 06-28-2009 11:13 AM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
Heat Pump set back GEAF HVAC 6 01-26-2009 08:49 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
heat pump not working kyleGR HVAC 2 05-30-2006 03:35 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
